UE 4 - 11,600+ Live Mass mailing attempt
Thread begun 3/25/2010 11:53 am by tom92909 | Last modified 3/29/2010 3:50 pm by tom92909 | 2392 views | 9 replies |
tom92909Beta Tester
Greetings folks.
Yesterday morning I performed a mass mailing of 11,600+ messages using the new Universal Email v.4.0 release.
Background: For the last 2yrs I've used the Linecraft Studio Email Merge Server Object for PHP (Dreamweaver Extension). It has performed this task of sending 9000+ messages consistently on a monthly basis for a client newsletter with some effort and serious babysitting.
My overall satisfaction with the product has been moderate to satisfied. The issues that I have encountered have been frustrating and required great effort to overcome. However, after 24+ real time uses, I have confidence in the process.
Linecraft Studio Email Merge Issues
1. Babysitting the process for up to 3hrs has been a pain.
2. End users not being able to see HTML version in email client.
3. Failures and process lockups.
With the beta and release of UE4, I was successful in running small blasts of up to 10 addresses and all worked without a hitch. We all did the beta and all seemed to have been worked out before release.
Yesterday I started the process and found that the log file (created by the UE4 script) was working as expected initially. I started getting an error after the 1st few hundred entries. The EmailError (TEXT) field in MySQL filled up as it appears to append all responses collectively.
Current MySQL Mailing List - 11643 records
At the end of 4hrs of running the total record count in the email_log table was 18183 records... ( I bailed on the process before it ended ).
I did a check in MySQL to see what the log had to provide...
WHERE `EmailStatus` != 'Success'
and found that 158 "FAILED" (not unexpected)
However the 6540 record difference is alarming.
*** Addition that I'd like to see ***
1. How can I use dynamic data in my message template? Perhaps I want to use a user ID, name or email address in my message to personalize the emailing.
I thought about placing this in the UE 4 forum, but decided that I should initially provide this information here instead.
I hope this creates some useful dialog.
Tom
"However the 6540 record difference is alarming."
that is odd... did you look for repeats in the to list to see if it was looping?
Was that a subset of your database, is it possble the filter wasn't maintained across the submit that initiated the email blast?
"The EmailError (TEXT) field in MySQL filled up as it appears to append all responses collectively. "
That also seems wrong, it should only show the most recent error in the log. I'll have to look into that some more.
You can add recordset references to the email body using the recordset that is looped for the to field.
tom92909Beta Tester
Below is the actual file I used to send the messages...
By the way... The progress bar didn't work, but once I got started, I didn't want to stop it to fix it. A nice addition would be a PAUSE button with a Recordset completed / Next Record ID to be submitted tracking system of some sort...
<?php require_once("webassist/email/mail_php.php"); ?>
require_once('Connections/email.php'); ?>
require_once("webassist/email/mailformatting_php.php"); ?>
if (!function_exists("GetSQLValueString")) {
function
GetSQLValueString($theValue$theType$theDefinedValue ""$theNotDefinedValue ""
$theValue get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch (
$theType) {
    case
"text":
$theValue = ($theValue != "") ? "'" $theValue "'" "NULL";
      break;
    case
"long":
    case
"int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case
"double":
$theValue = ($theValue != "") ? "'" doubleval($theValue) . "'" "NULL";
      break;
    case
"date":
      break;
    case
"defined":
$theValue = ($theValue != "") ? $theDefinedValue $theNotDefinedValue;
      break;
  return
$theValue;
mysql_select_db($database_email$email);
$query_getEmail "SELECT mailmerge.emailaddress FROM mailmerge WHERE mailmerge.active = 'Y' AND mailmerge.html = 'Y' ORDER BY mailmerge.recid ASC";
$getEmail mysql_query($query_getEmail$email) or die(mysql_error());
$row_getEmail mysql_fetch_assoc($getEmail);
$totalRows_getEmail mysql_num_rows($getEmail);
if (!isset($_SESSION))session_start();
if ((
$_SERVER["REQUEST_METHOD"] == "POST"))     {
//WA Universal Email object="mail"
set_time_limit(0);
$EmailRef "waue_WA_newsletter_March2010_1";
$BurstSize 500;
$BurstTime 1;
$WaitTime 1;
$GoToPage "";
$RecipArray = array();
$StartBurst time();
$LoopCount 0;
$TotalEmails 0;
$RecipIndex 0;
// build up recipients array
$CurIndex sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
$RecipArray[$CurIndex][] = $row_getEmail;
$RecipArray[$CurIndex][] = $getEmail;
$RecipArray[$CurIndex][] = "emailaddress";
$TotalEmails += mysql_num_rows($getEmail);
$RealWait = ($WaitTime<0.25)?0.25:($WaitTime+0.1);
$TimeTracker = Array();
$TotalBursts floor($TotalEmails/$BurstSize);
$AfterBursts $TotalEmails $BurstSize;
$TimeRemaining = ($TotalBursts $BurstTime) + ($AfterBursts*$RealWait);
  if (
$TimeRemaining < ($TotalEmails*$RealWait) )  {
$TimeRemaining $TotalEmails*$RealWait;
$_SESSION[$EmailRef."_Total"] = $TotalEmails;
$_SESSION[$EmailRef."_Index"] = 0;
$_SESSION[$EmailRef."_Remaining"] = $TimeRemaining;
  while (
$RecipIndex sizeof($RecipArray))  {
$EnteredValue is_string($RecipArray[$RecipIndex][0]);
$CurIndex 0;
    while ((
$EnteredValue && $CurIndex sizeof($RecipArray[$RecipIndex])) || (!$EnteredValue && $RecipArray[$RecipIndex][0])) {
$starttime microtime_float();
      if (
$EnteredValue)  {
$RecipientEmail $RecipArray[$RecipIndex][$CurIndex];
      }  else  {
$RecipientEmail $RecipArray[$RecipIndex][0][$RecipArray[$RecipIndex][2]];
$EmailsRemaining = ($TotalEmails$LoopCount);
$BurstsRemaining ceil(($EmailsRemaining-$AfterBursts)/$BurstSize);
$IntoBurst = ($EmailsRemaining-$AfterBursts) % $BurstSize;
      if (
$AfterBursts<$EmailsRemaining$IntoBurst 0;
$TimeRemaining = ($BurstsRemaining $BurstTime 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
      if (
$TimeRemaining < ($EmailsRemaining*$RealWait) )  {
$TimeRemaining $EmailsRemaining*$RealWait;
$CurIndex ++;
$LoopCount ++;
session_commit();
session_start();
$_SESSION[$EmailRef."_Index"] = $LoopCount;
$_SESSION[$EmailRef."_Remaining"] = round($TimeRemaining);
session_commit();
wa_sleep($WaitTime);
      include(
"webassist/email/waue_WA_newsletter_March2010_1.php");
$endtime microtime_float();
$TimeTracker[] =$endtime $starttime;
$RealWait array_sum($TimeTracker)/sizeof($TimeTracker);
      if (
$LoopCount $BurstSize == 0)  {
$TimePassed = (time() - $StartBurst);
        if (
$TimePassed < ($BurstTime*60))  {
$WaitBurst = ($BurstTime*60) -$TimePassed;
wa_sleep($WaitBurst);
        else  {
$TimeRemaining = ($TotalEmails$LoopCount)*$RealWait;
$StartBurst time();
      if (!
$EnteredValue)  {
$RecipArray[$RecipIndex][0] =  mysql_fetch_assoc($RecipArray[$RecipIndex][1]);
$RecipIndex ++;
$_SESSION[$EmailRef."_Total"] = 0;
$_SESSION[$EmailRef."_Remaining"] = 0;
session_commit();
session_start();
  if (
$GoToPage!="")     {
header("Location: ".$GoToPage);
?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<script  src="webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
<script  src="webassist/progress_bar/WA_newsletter_March2010_Universal_Email_1_Progress.js" type="text/javascript"></script>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
<style type="text/css">
@import url("plugins/webassist/progress_bar/WA_newsletter_March2010_Universal_Email_1_Progress.css");
</style>
</head>
<body>
<div id="START NEWS_ProgressWrapper">
<form method="post" name="START NEWS" id="START NEWS">
<input name="Submit" type="submit" value="START NEWS" id="Submit" />
</form>
</div>
<div id="START NEWS_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
<script type="text/javascript">
WADFP_SetProgressToForm('START NEWS', 'START NEWS_ProgressMessageWrapper', WADFP_Theme_Options['WAUE:Slate'], 'WA_newsletter_March2010_Universal_Email_1_Progress');
</script>
<div id="START NEWS_ProgressMessage" >
<?php require_once("webassist/progress_bar/WA_newsletter_March2010_Universal_Email_1_Progress.php"); ?>
</div>
</div>
</body>
</html>
mysql_free_result
($getEmail);
Tom
I can't see the problem... If you post your phone number I'll call you and help you debug the issues you reported. I'd live to find the fix and figure out what happened.
tom92909Beta Tester
Let me know if you want to contact me today.
Tom
yeah, post your contact information or email me with it at ray@webassist.com
tom92909Beta Tester
Thanks for your time and assistance Ray! :)
I just remembered one topic we didn't cover in the phone call...is there a way to include the following in the message body and or URL links embedded in the message template.
I'm using the center.php message template.
I have hyperlinks that I want to include specific user data to assist in tracking.
Example:
SQL Query: SELECT * FROM mailmerge WHERE mailmerge.active = 'Y' AND mailmerge.html = 'Y' ORDER BY mailmerge.recid ASC
html:
<h1><a href="http://www.webassist.com/1269325391.php?id=$RecID"><font color="#FFFFFF">March 2010 Features:</font></a></h1>
How are these recordset bindings ported over to the message template?
Same thing for if I wanted to personalize the message and perhaps include either the
message recipients name or email address in the body of the message.
Tom
Please post the syntax that you got working for this problem. Maybe others will benefit from knowing it.
tom92909Beta Tester
Once again Ray, thank you very much for your personal attention today. I hope that you were able to take away some ideas that will benefit us all in future releases...
The issue that I was having is that I could not call specific recordset data in my message template. With some examination Ray was able to show me how to call any field from my recordset into my message so that I could personalize my newsletters.
<a href="http://www.webassist.com/example.php?id=<?php echo $GLOBALS['RecipArray'][$GLOBALS['RecipIndex']][0]['recid']; ?>"><http://www.webassist.com/images/forums/webassist_forums_logo.png" border="0"></a>
OR perhaps include the recipients email address in the body of the message...
<b><?php echo $GLOBALS['RecipArray'][$GLOBALS['RecipIndex']][0]['emailaddress']; ?></b>
