Data assist crashing
For some reason today data assist is crashing when i try run the wizard.
I used it to genrate me insert update results etc pages. the reults page never display the modular images i chose even though it showd in preview.
no when i try re run it to generate my resuls page it just hangs on checking file activity in dreamweaver pop up.
i tried deleting my cache file, tried the normal restarts and checked i could connect to my site via ftp. also tried re naming the generate file names within dreamweaver to see if the default names were causing an issue but nothing. i cannot get data assist now to work at all.
can you guide me through anything that could be causing the issue??
many thanks
It seems that you can't connect to your database from Dreamweaver, which is normal because a lot of database connections don't allow for remote connection.
