Problem with DFP combined with DA update
Thread begun 3/23/2010 9:01 pm by blackweldermhe400113 | Last modified 3/29/2010 9:04 am by Ray Borduin | 5642 views | 13 replies |
Alright...
The problem I'm having is that the value of the hidden form field isn't populating the DFP file field upon loading of the update page. Meaning, for instance, if I go to update a record from my results page the existing file name in my database for my image isn't passing to the dfp as a default value. I've set the default value for the DFP to the hidden form field, and in the update record behavior I've bound the column name of my image to the server name binding in the WA Update Field. What I'm I doing wrong? I've sat here for hours trying to get it to work properly and don't know what I'm doing wrong. I've followed the pdf for adding the DFP to a DA update and insert pages. The insert pages are working fine, but I can't seem to get it to work properly with the update pages.
Please help!
Jimmy Wu
Make sure in the code for the upload server behavior that the default file name is being set:
'DefaultFileName' => "<your file name here>",
If that is blank, try opening the behavior again and setting the default file field and hitting tab before hitting finish.
Default file name...
That was one of the first things I did. I looked all through the forums last night also. The file name is being sent. Any other ideas or will I need to attach my file along with the next post?
Jimmy Wu
Yes, if you could send your files so I can take a look at them, that would be great.
Product Update Page
I've attached the products update page. There is only one instance of the DFP now, but will be multiple instances, one for each image field, upon resolution of this problem.
nickj
I have the same issue
I've checked the Defaultfilename= and it's empty " " nothing I do will populate this field. Next I will try hard coding.
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../pub/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
nickj
Odd fix!
Since i had the WD Upload File in the server behaviors and I had my cursor in the code rather than the page view, updating the WA Upload Files accepted the edit. It seem as though going from the code panel to the server behaviors did the trick!
Still in need of a solution.
I was working on this over the weekend and still haven't been able to get it to work properly. I'm still in need of a solution.
nickj
Odd fix didn't work the second time.
Still no solution. I had to copy the default file code from the the dialogue box and paste it into the the Default File= in the source code. Not a very nice solution.
Problem is the default value for the file name is showing in both the binding and code view.
