Google Maps - Have Login?
Thread begun 3/23/2010 6:15 am by tonygmg362159 | Last modified 4/09/2010 3:08 pm by Jimmy Wu | 2147 views | 3 replies |
tonygmg362159
Hi All,
I have emailed webassist sales department but as of yet I havent receieved a reply.
The question in which i would like to ask;
Does the client have to login in and change the google maps directly if they want to add a new destination or can this be done by simply from the client side of the map being in the page?
Jimmy Wu
To add an additional map point, it would be much easier to make the modification through the Pro Maps interface. There is no built in "add point" functionality for the user side.
Bryan Miller
Tony,
You could easily add a form in Dreamweaver to allow the end-user to submit an address to map. You would need to use dynamic mapping data rather than static. Instead of fetching the map data from a database you would simply map the data the user submitted.
Jimmy Wu
Yes, creating a form to insert new points into a database and displaying from that database would work to add points to a map.
