uEmail 4 not working!
Thread begun 3/22/2010 3:06 am by jebrandon343719 | Last modified 3/22/2010 3:33 pm by jebrandon343719 | 1953 views | 4 replies |
jebrandon343719
Hi, The new Universal email is not working for me. I have used old version many times, so think I have set all parameters correctly, but nothing is begin sent.
Code attached. If you wish to check.
v4 has bindings added to help you diagnose errors. Drag and drop the error message from the bindings tab to see if it thinks it sent properly or if any errors occurred. That is the best place to start. Then maybe try checking spam filters, it is pretty common for the email to be sent but get spam blocked for one reason or another.
jebrandon343719
Cool feature
Hi , What a cool feature!. I dropped in the 'last error'. When I loaded the page - this is what I got.
Failed to connect to mailserver at "mail.apiaust.com.au" port 25, verify your "SMTP" and "smtp_port" setting in php.ini or use ini_set()
Just not sure what to do with this info!
jebrandon343719
Progress
Have progressed a little - this error behaviour is really helpful.
I am now getting the following error ??
mail() [function.mail]: SMTP server response: 550 <jill@mydomain.com.au> Relaying denied
Sending To: jill@mydomain.com.au... mail() [function.mail]: SMTP server response: 550 <jill@e-assist.com.au> Relaying denied - Failure
PS: Just changed domain name in the above to mydomain for security reasons.
jebrandon343719
Blank email
Hi, Got the last bit sorted. Hosting company provided me with a mail server to use.
I then could send an email but it was in my jubk box with no 'body content' !
I had all sorts of issues with this. I had to make sure a i used a file for the email - otherwise the body of the email was blank. Also, had to make sure this file was uploaded. It didnt upload with dependant files.
Maybe I'll get used to this, but I did prefer the last version of Universal Email.
Thanks - all sorted now.
PS: the error behaviour is an excellent feature!
