'cart is empty' instead of Success page?
Thread begun 3/18/2010 10:54 am by moniquenw362187 | Last modified 3/18/2010 2:18 pm by Eric Mittman | 1421 views | 1 replies |
moniquenw362187
I'm having problems with the Success page not showing up all the time. More often than not, the only page that shows up after you hit Submit is cart.asp, which says the cart is empty. The order went through just fine, but the customer does not know this, unless they check their email. I'm thinking there's something on the Success page that tells it to empty out to the cart and redirect it to cart.asp but I can't find out where that might be.
There is normally code on the checkout pages that will check to see if there are any items in the cart, if not you will be redirected back to the cart page. You say more often than not that this page does not work correctly. Have you noticed any pattern to it, does it always do this if a particular item is purchased? Also, is your checkout working with https pages only? Please post back with these details and a copy of your checkout success page so that we can take a look.
