template changes
Thread begun 3/16/2010 8:28 pm by westmorelandgraphics311771 | Last modified 3/18/2010 10:47 am by Eric Mittman | 3817 views | 5 replies |
template changes
I made changes to powerstore200's main template in dreamweaver, updated all of the pages using that template, and uploaded them to my site. Now, the pages are missing all of the formatting and I'm getting these error messages.
Warning: require_once(../CSSMenuWriter/cssmw_home/menu.php) [function.require-once]: failed to open stream: No such file or directory in /home/denwest/public_html/store/AboutUs.php on line 179
Fatal error: require_once() [function.require]: Failed opening required '../CSSMenuWriter/cssmw_home/menu.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/denwest/public_html/store/AboutUs.php on line 179
I also re-uploaded the css and CSSMenuWriter folders. I don't know what this means or how to fix it. I'm not sure what to do next.
Here's the link to this page-
AboutUs.php
Thanks for your help.
It looks as though there are a few issues with linking to the other files on your pages. When I check the source I can see that they are all set to file system paths. It looks like when you made these edits you did not have the site properly defined in DW. You must first have you site setup in DW including the testing server info so that any changes you make will be incorporated into the site correctly.
The Warning: require_once(../CSSMenuWriter/cssmw_home/menu.php) error is letting you know that you have the menu writer include referenced on the page with a ../ in front of it. You need to make sure that it does not have this ../ in front of the path on your page.
If you have a hard time getting it all set back up you should revert to the original downloaded files and start fresh with those. Make sure that you define your site in DW before you attempt to make any changes or you can have other issues as well. Here is a link to a how to on getting your dw site defined:
dynamic_site_definitions.php
H, Eric,
I have had a helluva time getting the testing server to work. I don't know enough about this to know what I am doing wrong, so, I just keep trying different things until something works. I have finally achieved some kind of connection, but, nothing shows up.
The DB is in place. I have been able to access it previously and add/update products online. I was doing everything live, because I always have trouble with the testing server. I understand that this is the best way to handle things, but, I'm getting grey trying to figure it out and get it to work. Your suggestions are greatly appreciated, but, please understand that I am very new at this and sometimes the simplest things escape my notice.
Here's the link-
index.php
Any idea what I am doing wrong?
Thanks. Denise
The link that you posted is for you own local machine. I will not be able to access the page at this address from the internet, you can only access this locally from your machine.
It seems like you were able to get your site defined in DW, did you also install a local testing server? If so what is the current error you are getting on the page locally? If you have not got a local testing server up and running here is a link to another doc that we have on this subject:
xampp_for_windows.php
Hi, Eric,
I'm on a Mac using MAMP. The testing server is up and running. I kept getting a blank page, so, I started from scratch with a clean copy of PowerStore. That did the trick. Any of the files that I open from DW can be viewed in my browser, but, the links from the navigation are not working. i.e. - when I click on contact, I get the error -
Not Found
The requested URL /contactus.php was not found on this server.
Apache/2.0.63 (Unix) PHP/4.4.9 DAV/2 Server at localhost Port 80
Is this a related issue or is something else happening? Thanks for your help.
Denise
The links in the menu should be based off of the root URL value that is in the wa_settings table in your PowerStore database. Check on the value in here, it should match the location of where you store the files within your webroot. This value should be the first one in the wa_settings table if you view the data.
On my local testing server setup I have the powerstore in a folder called powerstore in my webroot. For me the root URL value is set like this:
powerstore/
