How to change Powerstore's appearance
Thread begun 3/15/2010 2:18 pm by david385393 | Last modified 10/11/2010 10:11 am by Ray Borduin | 4329 views | 7 replies |
david385393
Hi , I will start by saying again I am a beginner in web development. I have purchased most WebAssist products the latest of which I have obtaioned is Powerstore. As much as I enjoy playing around with the packages to find out myself how to get things done, on this occasion I would like a few pointers where to begin.
I have designed a site for a friend and am now looking to change powerstore's appearance to look like the website in areas like header image, background colours etc and menu of course. I understand most of this will be in the CSS side of things. I am wondering if there are any basic guidelines to follow to achieve all this, What are the main files to look for and changes to be made?.
Is there any pitfalls I should avoid . I have installed the package on the testing server and all seems to be working fine except for the appearance.
Thanks in advance for any help
David
Jimmy Wu
For the header image, you would want to find the image with this source that is contained in the header:
/jwu/Powerstore300/Images/logo.png
Then you would change the source to the image you want or just replace the logo.png with your own logo.png.
The colors of the PowerStore are controlled by the common.css, home.css.
To change the menu's color and styling you would either edit it using Menu Writer or modify the CSSMenuWriter/cssmw_home/menu.css
If you run into any issues with changing the styling, feel free to post a new thread or reply to this one.
david385393
How to change powerstore's appearance
Thanks for this. I will get to work right away. Will contact you again if I hit any problems.
Jimmy Wu
Great, g'luck and let me know if you run into anything.
KJT
Logo Size
I would like to make the logo bigger but when I replace the file with a bigger logo, the logo distorts. I tried to look the template to edit the area to make it bigger but I am at a loss on how to do this. Any help on this matter is appreciated.
Do you have a sample page. You should be able to update the image in the html. If it changes size, then maybe see if there is css controlling the dimensions. If I could see an example I could probably tell you exactly what to update.
KJT
I took a look but I can't see what is causing it, it is probably something simple that I have missed! Here is example: www.hairandbeautyonestopshop.com/ and I have also included attached index file. Thanks.
It looks like the image itself has both a height and width specified in the <img> tag.
I believe that image reference is on the home page template, so you would have to update the html to correct this issue.
