Some questions about Power Store 3
Thread begun 3/11/2010 1:44 pm by Gabriel Tiviroli | Last modified 3/12/2010 1:16 pm by Eric Mittman | 2237 views | 2 replies |
Gabriel Tiviroli
Hello friends, I am buyer of nearly all software and subscriber Extensions library.
The last thing I bought was the Power Store 3. I've installed on my server to test it and I had certain doubts.
The first sign that after, as trustee, and when I try, for example, the Order History, I check e-mail requests. Well, log into my email account and I see there a URL to get verification, but has no code, below, I give the example of what has come to me, and then while I'm by verified when I try again make entry into the Order History tells me that the email has not been verified, when in fact already has been. How to solve this? below the example that comes to my email:
Please follow the link below in order to verify this email address:
users_Confirm.php?ID=1&code =
As you can see, there is no code to the end and I think that is why I get the error and ask me to check again, I can do?
On the other hand I want to know if you can change the look of the store and as it should and everything works on line and not in local mode.
And finally, being that comes with the CMS built store, I notice that there are adding content to paste php code on the site of the store. But in that case, if you make a purchase for a client, I guess it is uncomfortable to have to understand how to make that step, and the idea is to provide a solution to the customer and not a problem. You can do about it?
the code that is sent in the email is stored in a session variable. try the sessionTest.php script in the following post:
showpost.php?p=23826&postcount=2
to see if sessions are working correctly on your sever.
Yes, power store can be edited locally, then uploaded to the remote host.
As the developer setting up power store for the client, you should create all of the pages that will be included in the site, and set up the content areas that will be managed by the client.
The verification code is needed for the URL in order to verify the user. When the user registers a new user record is stored in the db in the ps3_users table. It is the verification code that is stored in here that is sent in the email message.
Can you check your ps3 database in the ps3_users table to see if there is a verification code for your user. If there is then there may be a problem with your email client and removing the verification code from the link. If this is the problem you should be able to register with a new user and a new email address that uses a different client, like gmail or hotmail.
The final questions that you have in regards to working online versus local and about the user experience with the CMS I'm not sure that I understand what is being asked. Please post back with some more detail about these issues so that I can help you out with them.
