web charts
Thread begun 3/10/2010 10:03 am by akstudio | Last modified 3/11/2010 6:40 pm by Eric Mittman | 2215 views | 3 replies |
akstudio
web charts
Can't "edit in wizard"
Ive seen the one thread stating that site definition needs to be root.
I think I need a bit of direction here as to how the site should be setup. I've basically did not change anything.. I've unzipped the Registration001 folder, and placed the files into my "My_Site" folder. Everything works except for the chart.
My admin page, where the chart resides, has a path of:
index.php
The "DynamicWebCharts" folder is:
DynamicWebCharts/
Do I need to move this folder into the admin and update the links (removing the ../)
Any help on this would be appreciated.
The file structure that you listed here is correct. You do not need to move the web charts folder into the admin folder. What is the result that you are getting? If you do not have any registered users there will not be any info to display in the charts.
akstudio
Fixed.. it was the path to my connections file.... was wrong.
Glad to hear that was the issue and you got it solved. Let us know if you have any other questions or if you encounter any further issues.
