Upload path potential problem
Thread begun 3/10/2010 5:00 am by web_assist_mail157665 | Last modified 3/26/2010 11:23 am by Ray Borduin | 7011 views | 15 replies |
I've set the global upload (Wizard) file path to
/userfiles/ (actually I just need userfiles/)
the path to my images are being entered into the database html (in the form)
src="/~MyUserName/SiteName/userfiles/image/ImageName.jpg"
it needs to be
src="userfiles/image/ImageName.jpg" ie as per the Wizard!
Otherwise when I upload the database - all the images are going to have invalid links?
The same problem will occur if I take the database sql from the server to work on it locally.
The current setup is not transportable?
Pls advise
PS - on a positive note - the file manager is a big improvement
Sorry to push - really need an answer on this one
I can't edit any images/files on my current site locally and have all the file paths wrong in the database when its uploaded
Dani Chankhour
The paths are written by HTMLEditor using site relative. so if the root of your site is under the "SiteName" folder, then the url is correct, and it should not add the "/~MyUserName/SiteName" to the beginning. Can you give me some information on how to reproduce the issue on my end? If i'm able to reproduce the issue, i can assist you in getting the issue resolved.
Also, please tell me if you are on a mac or pc and the version of DW, and if you are using the Advanced Image Upload?
Thanks.
Originally Said By: Dani Chankhour
Thanks.
Local development on a PPC Mac 10.4.11
PHP MYSQL
DW CS4
Upload - using HTML Editor file manager
As you know - sites (by default) are are stored in the user folder 'Sites' - hence the prefix
and thats where I've always had them
a typical path locally being
index.php?
Looking in the HTML Config it is set up as
$WA_EditorLocalRoot = '/~UserName/SiteName/';
$WA_EditorRemoteRoot = '/~UserName/SiteName/';
obviously substituted UserName and SiteName
Each text article is editied with HTML Editor
and images in the text are uploaded via HTML editors filemanager
That article text (including links) is written to the database
more
my main file folder is 'userfiles'
my images are in that folder, in another folder called 'image'
the index.php file is in the Mac Site folder
index.php
>userfiles>image>imageappearinginindex
an image appearing on the index page should have src="userfiles/image/imagename.ext"
the html editor(s) are being called from a php file in a sub folder CMS
>cms>form_edit_article.php
From what I have experienced I cannot believe that HTML editor was ever even tested on a standard mac web setup
if the code goes looking for the apache root folder and inserts that into all the image filepaths
(another annoyance - after picking the default upload folder as 'userfiles' it is displayed in the filemanger as 'root'?? - root seems to be misunderstood and misued all round)
Yes the true root is the apache server - but that's completely useless to include that in the image filenames!
And just to finish things off...I change the upload default directory from /userfiles/ to userfiles/ - and all the editors stop working - no database text - no upload
The upload directory should have nothing to do with the managers interface!
So I go to EDIT the interface and the wizard gives me a javascript error and refuses to open
Now I'm totally screwed
3 days down - still not able to put images onto site.
My client is going ape sh*t
....editors back
no change on path problem
I really need this resolved soon please.
Hi Guys- it's just turned 9:00 pm here
I really need to sort this out before 11pm
Dani Chankhour
I have opened a support ticket to further assist you with this issue:
Thanks Dani
Its on the server - you have details of ftp in support ticket
Its getting late
getting on for 1 in the morning
going to call it a night
I need to know
1) can you get the editor to show images
2) and get the editor to insert images with filepath
src="userfiles/image/....etc)
ie what you expected it to do the moment it was installed?
there is obviously something fundamentally wrong with the way the file paths are worked out
tia
Dani Chankhour
Thanks.
I just responded to your support ticket. I just want to clarify that the HTMLEditor was fully tested on MAC. And the url that you are getting are the correct url and they should work with your default mac set up. and when you upload to your remote server, you can change the $WA_EditorRemoteRoot = '/~UserName/SiteName/'; setting to match your remote server.
This is WRONG WRONG WRONG!
If you have a wizard which sets the upload folder the user SHOULD NOT BE EDITING CODE!!!!
This application doesn't work and needs fixing.
If I set a RELATIVE folder as usefiles/
in a wizard - then thats the RELATIVE folder - be it on a server locally or remote or where ever.
If the database gets a fixed path from the root of the server locally (you must realize that a local mac server puts the Users name in the file path from the apache root!) for every image - then the database entry is USELESS when uploaded.
Site relative us USELESS and is not transportable.
How you can think this is working correctly is beyond me!
BTW - Even IF you MANUALLY CHANGE THE CODE on the server
the images still DO NOT APPEAR IN THE HTML EDITOR WINDOW
The (unknown image) may get the right path from the third party filemanger - but you cant see what images are on the page
This application is flawed - please prove me wrong
It all seems to have gone quiet since last week. No response from tech!
I'm still stuck here with image and file names going into the database with the whole server address on them.
If I change the config files to clip them off - fck editor just shows placeholder ?
Running out of time - please take a look at this issue.
