How to properly add tax of shipping costs?
Thread begun 3/09/2010 3:11 am by jernej | Last modified 3/12/2010 5:02 pm by Jason Byrnes | 2611 views | 3 replies |
jernej
Hi there
In my country we have 2 taxes, 8.5% and 20%. The postage goes in 20% tax.
Now I have a shopping cart and let's say we have postage 2 €. That is total, postage + 20% tax. So I added a shipping rule of flat rate at 1.67 €.
What I need to do now is to say e-cart this postage acts like an item or something, because I have to add the 0.33 € to the taxable total of 20% tax. Using the checkbox to include postage to taxable total didn't work, maybe because we have 2 tax rules, how would ecart know I need to make a tax added to the 20% rule?
I can "hack" e-cart rule to manually add the 0.33 to the sales tax, but because we have 3 postages (I was talking of 2 € just for the example), I can not make that a flat rule. The worst part is if I mungle with tax in eCart1_VB.asp and add the shipping totals to the rule manually every time I open the ecart GUI my postage rules are rewritten, so this is not a good option.
How is the proper way to do this? There must be a way to say to the tax rule I want my postage rules to be included in tax and in which tax? Can I make a calculation for this?
This is puzzling me for 6+ months, I have "solved" this by manually tweaking the tax rules, but it has done more bad than good as I have to copy paste back my shipping rules every time I change something.
The problem I see lies in the fact I can not use the TaxableTotal as in my country I have to state separately the 8.5% tax and the 20% tax, so I need 2 rules which takes values from my item price * tax totals, not the taxable totals. Taxable totals work ok only if you need total of paid tax, but I need 2 different taxes to show in cart and the postage must be added to one of them (20% one).
Thank you for your help
Yours
Jernej
PS - I have eCart 4.5.2 with ASP
I will need some more information to be able to come up with a solution.
From what you are describing, your question is basically: How to calculate 20% of the Postage.
How are you calculating postage? What is the rule you are using for postage? This will help me determine how to calculate the 20% tax.
jernej
Thanx. I know how to calculate 20% of the postage, but how to add 20% of the postage to the TAX calculation is my question? Because I have 2 tax-es (8.5 and 20%) and the postage falls into 20% one.
So if I make a postage rule and tick the option to include it into tax, it works. But works only in Taxable total. So taxable total carries the tax for the postage. But I need it to go to the 20% tax rule, not taxable total...
I've come today with some kind of solution (half), to add to my 20% tax rule the postage calculations * 0.20.
I'll write here all my relevant rules, so perhaps you can see what I am trying to do. This works now, but it is not a good solution:
Here are the 3 postages:
function WAEC_eCart1_PostninaPravne1()
totalShipping = 0
if (true AND ((UBound(eCart1.Items) > 0))) then
totalShipping = totalShipping + 1.67'Result
end if
WAEC_eCart1_PostninaPravne1 = WA_eCart_FormatNumber(totalShipping, eCart1.ForceDecimalsC, eCart1.DecimalPlacesC)
end function
function WAEC_eCart1_PostninaPravne2()
totalShipping = 0
if (true AND ((cStr(Session("tip")) = "1") AND (WA_eCart_TotalColumn(eCart1, "Quantity") > 5))) then
end if
WAEC_eCart1_PostninaPravne2 = WA_eCart_FormatNumber(totalShipping, eCart1.ForceDecimalsC, eCart1.DecimalPlacesC)
end function
function WAEC_eCart1_PostninaPravne3()
totalShipping = 0
if (true AND ((cStr(Session("tip")) = "1") AND (WA_eCart_TotalColumn(eCart1, "Quantity") > 10))) then
totalShipping = totalShipping + 2.5'Result
end if
WAEC_eCart1_PostninaPravne3 = WA_eCart_FormatNumber(totalShipping, eCart1.ForceDecimalsC, eCart1.DecimalPlacesC)
end function
Here are both taxes:
function WAEC_eCart1_SalesTax8()
totalTax = 0
if (true AND ((WA_eCart_ConditionalTotal(eCart1, "Quantity", "Tax", "0,085") > 0))) then
totalTax = totalTax + (WA_eCart_ConditionalTotal(eCart1, "DDVSkupaj", "Tax", "0,085"))'Result
end if
WAEC_eCart1_SalesTax8 = WA_eCart_FormatNumber(totalTax, eCart1.ForceDecimalsC, eCart1.DecimalPlacesC)
end function
function WAEC_eCart1_SalesTax20()
totalTax = 0
if (true AND ((WA_eCart_ConditionalTotal(eCart1, "Quantity", "Tax", "0,2") > 0) OR (( cDbl(WA_eCart_GetShipping(eCart1))>0 )))) then
totalTax = totalTax + (WA_eCart_ConditionalTotal(eCart1, "DDVSkupaj", "Tax", "0,20"))+cDbl(WA_eCart_GetShipping(eCart1))*0.20'Result
end if
WAEC_eCart1_SalesTax20 = WA_eCart_FormatNumber(totalTax, eCart1.ForceDecimalsC, eCart1.DecimalPlacesC)
end function
The DDVSkupaj is the [Price] * [Tax] as I have in database neto price and tax value (0.2 or 0.085)
Now this kind of works, but is it smart to add custom function to 20% tax:totalTax = totalTax + (WA_eCart_ConditionalTotal(eCart1, "DDVSkupaj", "Tax", "0,20"))+cDbl(WA_eCart_GetShipping(eCart1))*0.20
As you see I had to use the custom function to add the GetShipping(ecart1)*0.20
The problem I see with ecart here is that it assumes all tax is in one value that is represented in taxable total. Here in Slovenia we have to specify in orders the 8.5% tax and 20% tax SEPARATELY. So taxable total doesn't help and so the check box to incude postage in tax doesn't help me.
I hope it is more clear now, but I am not sure :-)
can you send a copy of the unedited cart include php file instead of posting the code here, so I can work directly with the calculations an reproduce the cart?
to attach the php file, compress it to a .zip archive and send the zip file with your reply.
