Gallery install
I have tried to install PG 3 times and can only get to admin with no galleries to edit.
Each time deleting the sql.db and PG folder and starting a fresh install only to get stopped by no content from the UI.
Any ideas?
Thank you
Any ideas?
Thank you
I just did a view source and it looks like half of the page's code is missing.
Maybe if you take the choose gallery file from the original zip and re-upload it into the admin directory, that will fix it.
I am not sure why the page is missing half of it's code.
Try reloading just that one file and inform what happens.
Regards,
Brian
Tried overwriting the file to no avail. Still the same.
It looks like the admin menu is missing and there could be other files that are missing or incomplete as well. As Brian pointed out, it looks like some of the code is missing on your choosegallery.php page as well. The best way would be to reupload the files from the zip and confirm all of them were transferred correctly.
Got it!
The serverside control panel that decompressed the rar file must have not completed or something? So I extracted all the files locally and then FTPd them to the directory and waalaa
Thank you for your time.
Cool, glad you got it all working.
