HMTL Editor Error
Thread begun 3/07/2010 3:43 pm by ideasbyjr63389 | Last modified 8/12/2010 3:17 am by cornelia.brodahl412884 | 2218 views | 3 replies |
ideasbyjr63389
HMTL Editor Error
I reloaded the WebData Assist Ext, now the HTML Editor , don't work. While trying to save it or working on setting this error pops up, and block the dreamweaver from doing anything else.
It seen if you are using to many of webassist extension, when you install them , they want to override each other files, Sometimes you get ask to replace, or keep, or that the one in the system is older, and this are files I'm talking about no just images.
It is kind of irritating when you are on a dead line trying to finish something, sometimes is like using a Windows computer and it freezes, in the middle of what your doing.
Any ideas what is causing this, O should I reload the operating system and them reload the extensions in a specific order so they don't override each other.
anonymous
This is 99.9% of the time caused by the cache error in Dreamweaver. If you ever want quick directions to fix this, check the Announcements section at the top of each thread (that's how prominent the cache issue has been).
Here's a quick link: announcement.php?f=20
Regards,
Brian
ideasbyjr63389
Thank You
Thank You for the quick response. Working like a charm
Additionally
I followed the helpfull instructions on common_installation_issues.pdf. However the problem persisted.
But then I stopped the caching process by exiting this dialogue window with the progress bar, *before* the "Runtime Error!" occured (... This application has requested the Runtime to terminate it in an unusual way...). Immediately DreamWeaver started properly!
