Received email without contact informations
Thread begun 3/03/2010 9:19 am by james276087 | Last modified 6/28/2010 12:32 pm by Jimmy Wu | 8737 views | 29 replies |
james276087
Good morning everyone,
After completed the Contact Form, i'm receving the email but without information.
I used the Universal email, i thought i did right...
please again little help..i attached the file
thanks for your time
James
contactus.php
Jimmy Wu
Did you add the information into the email? When in Universal Email, you will have to edit the email body and add the dynamic bindings to the email for the information to be sent to you.
james276087
This post has been deleted.
james276087
james276087
I did after you told me, i really confused on Body section.
I did so many different way and sometime i was getting message without space between contact informations.
Now Contact me button doesn't go to the other page....please advice
contactus.php?invalid=true
Jimmy Wu
It looks like your page is down now. What you could try is to create a new page and apply the form again. Then apply universal email from scratch.
Try following this tutorial on how to send form information:
02_sending.swf
This can be found on the support page for universal email as well as some other tutorials:
universal-email/
james276087
Hello Jimmy,
Please check my page again it is up now
? Contact me button doesn't changed to new page??
thanks
Jimmy Wu
Could you send me this page in an attachment on the forum, so I can take a look at it? One of the validations seems to be failing, so it is failing to go to the next page.
Also, is this the original page or the new page that you created? Try creating the form again on a blank page to see if the validation is working or not. Something could have been corrupted when you were making modifications for the email.
james276087
thanks again for your time n i attached the file as pdf file....
and i will make the form on new page
james276087
Hello Jimmy,
thanks for your patient.
I uninstalled , cssformbuilder n universal email and reinstalled those.
And i created the form on this page.
It is fresh(?) so you might find my mistake from this page..thanks
Also you could see the little black box(?)
contactus.php
