DataAssist insert page - insert/update two tables at once?
Thread begun 2/25/2010 7:30 am by jeffmg279672 | Last modified 3/01/2010 11:55 am by Dani Chankhour | 2529 views | 5 replies |
jeffmg279672
I have two tables and rather than set up a separate insert/update/delete page for each of them, wondered if it's possible to set up a single page for each function that will (on Insert/Update being pressed) update the two tables simultaneously, or whether there isn't a shortcut here.
If it's possible and there's documentation on it somewhere I'd appreciate a pointer in that direction.
Also - unlike some who post on here I don't have anything but good things to say about the standard/response time of support from WA - I've been bailed out by you more times than I can remember, and always with unfailing courtesy and patience. Thanks a lot.
Dani Chankhour
Thanks for your comments.
Yes, you can just apply additional insert, delete, and update DataAssist server behaviors to the same page. The only thing you need to watch out for, is make sure that you don't have any redirect setup till the last server behavior is ran.
jeffmg279672
Thanks for that Dani - I'd wondered about trying to create a second insert immediately below the first one - at the end of the code for the first insert page comes this:
if ($WA_redirectURL != "") {
So if I read you correctly, should I insert the second insert behaviour before this section?
I wasn't sure whether to try running the wizard a second time on the same page, or setting up a separate page to do the second insert then copying and pasting the code from this immediately below the first one (if you see what I mean).
Dani Chankhour
It really does not matter which insert server behavior comes first or last, you can just add the server behavior to the same page. Just make sure that the last server behavior on the page is the one that have a redirect to a separate page if you do have a redirect otherwise you should have to worry about which order to have the inserts.
jeffmg279672
The attachment contains two insert pages which are designed to create new listings on two linked db tables. I'd like to combine them on one page but I'm not sure how to do it as each redirects to a different page. I'm not clear whether I can copy and paste the WADAInsertContainer from one page into the other and delete one of the redirects, or whether I need to do something more complicated than that. Any guidance appreciated.
Dani Chankhour
Yes, you should be able to just copy and past the insert server behavior from one page to another and place it under the first insert server behavior and just make sure to remove the redirect from the first insert server behavior to the second.
I also noticed that you have applied Digital File Pro server behaviors, so just make sure that you copy that. And as long as all the includes files are there the server behavior should work. And it looks you are using the same trigger name, so that should be fine.
