Fatal Error Uploading Images
Thread begun 2/22/2010 12:40 pm by Sailors | Last modified 2/24/2010 9:15 am by Sailors | 3116 views | 4 replies |
Sailors
I have 3 fields and applied the upload server behaviour on all three fields.
Issues:
1. When I tried to upload and resize 3 pictures of (3168x4224) 5.97mb each it doesn't upload, nothing happens. But the upload works when uploaded individually.
2. When I tried to upload 2 of the pictures I get this error message: "Fatal error: Maximum execution time of 30 seconds exceeded in C:\siteroot\WA_DigitalFilePro\HelperPHP.php on line 932". How do I increase the execution time, and prevent this kind of error message.
3. How do I get the upload status error messages to display in the browser. Something like "Uplaod Successful" for the user to know the upload status.
4. Is it possible to resize and resample the images so that they occupy the specified fixed width and height without the fill color. I read how to adjust the position of the image by setting the co-ordinates from this post showthread.php?t=8168. But my problem with this method is setting and testing the x,y co-ordinates to centre a particular image, what happens when the image is of a different size, smaller or bigger. So I'm wondering if there's a way to get the images automatically centred for different sizes.
1-2) Add the following code at line 1 of you page to increase the server memory limit and execution time settings:
ini_set
('memory_limit', '256M');
ini_set('max_execution_time', 120);
3) See the "Customizing Digital File Pro Error Messages" tutorial in the How to section of the DFP support page:
digital-file-pro/
4) When the upload is set to Web Images only, the re size options include Fit to Height, fit to width or fit to box. These options do not use the fill color and will set the image to dimensions you specify.
Sailors
Thanks Jason. I'm grateful.
Sailors
Hi Jason,
Regarding your suggestion to increase the server memory and the execution time, it didn't solve the problem. I pasted the code on the upload page it didn't work. I edited the php.ini file and increased the server limit to 256M and the execution time to 120 yet it didn't upload.
Like I said earlier I have 3 file fields. It uploads and resizes all three fields when I have smaller image sizes but when I try 3 images of 5.97Mb (3168 x 4224) nothing happens.
Any suggestion?
Sailors
Ok sorry, I've sorted it. I had to increase the post_max_size.
