trying to modify menu in PowerStore
Thread begun 2/21/2010 8:10 am by info386313 | Last modified 2/24/2010 4:14 pm by Jason Byrnes | 4272 views | 9 replies |
info386313
I'm having a problem trying to modify the menu nav through the menu writer in DWCS4. I click to thicon script then click to the edit content and then the menuwriter extension opens with a message error: "The database conection for this for this content preset do not exist.."
I check the the PowerStoreConnection in my db conector in DW and it looks fine: I see the tables and the data. Any idea what is going on?
also, another thing: once the message appears, when I click "accept" there is no way I can exit the application and I need to force to do it
markymark44
Hi Info, are you editing the php files in the folder of CSSMenuWriter?
info386313
Originally Said By: markymark44
Not at all. I just take the template file and I try to change the menu content. That means double click into the menu div and down bellow in the properties panel I see that I could edit it with menu writer extention. Or, either way, I click to the php icon and i see the same result in the properties panel.
I don't go through any code at all.
neilo
Hi Info,
See this post
info386313
PowerStore 3 interaction with Ecart5
I'd like to customize PowerStore with Ecart. One thing I want to do is changing the currency. I took the Powerstore CART OBJECT and try to edit it in ECART changing currency in Localhost. I had message errors coming after I saved the file.
Can I change things into Powerstore script through ECART5 (currency, spanish languaje, etc...)
thanks for the quick reply of the other post!
Yes, you can use eCart to make modifications to PowerStore.
For changing the currency, see our "Changing PowerStore's Currency" tutorial on the Power Store support page:
powerstore/
The errors you report may be fixed by deleting the Dreamweaver cache file from the users configuration folder:
info386313
thanks for your reply. I saw the post about changing currency without Ecart but as you mention I can use ECART anyway I change the cart with languaje=spanish, currency=€, and save the file.
I test it on my localhost the here is the message with the mozila:
"Parse error: parse error in C:\wamp\www\power\WA_eCart\WA_Store_Cart_PHP.php on line 114"
please send a copy of the WA_Store_Cart_PHP.php file.
info386313
i'm sending you the file attached.
change line 114 to:
if ($WAGLOBAL_Shipping_Enabled == 1 && (("USPS"=="USPS")&&(isset($_SESSION["WA_Store_Cart_USPS_Quote"]))&&(floatval($_SESSION["WA_Store_Cart_USPS_Quote"]) != 0))) {
change line 123 to:
if ($WAGLOBAL_Shipping_Enabled == 1 && (("FedEx"=="FedEx")&&(isset($_SESSION["WA_Store_Cart_FedEx_Quote"]))&&(floatval($_SESSION["WA_Store_Cart_FedEx_Quote"]) != 0))) {
and line 132 to:
if ($WAGLOBAL_Shipping_Enabled == 1 && (("UPS"=="UPS")&&(isset($_SESSION["WA_Store_Cart_UPS_Quote"]))&&(floatval($_SESSION["WA_Store_Cart_UPS_Quote"]) != 0))) {
