Photo won't upload
Thread begun 2/16/2010 7:42 am by koneill385535 | Last modified 2/17/2010 3:36 pm by koneill385535 | 3319 views | 5 replies |
koneill385535
Photo won't upload
I am using Digital File Pro with my Insert page from DataAssist, but when I add things to the Insert page, it never saves the image that I select to PHPMyAdmin. When the detail page comes up, all the other information is there, but not the photo. What could I be doing wrong? Any ideas?
Attached is a screenshot of my Insert page if it helps.
Dani Chankhour
Make sure that the Digital File Pro upload server behavior is above the DataAssist insert Server Behavior.
koneill385535
It was. I still get this look when it takes me to the detail page.
Dani Chankhour
You might need to prefix the image source with a folder name if the images are saved in a special folder. For example:
Your image tag might look something like this:
<img src="<?php echo $row_WADAProducts['ProductThumb']; ?>" alt="" />
But if the image are stored in an imageupload folder, then you need to update it to say:
<img src="../imagesupload/<?php echo $row_WADAProducts['ProductThumb']; ?>" alt="" />
Also, is the image name being stored correctly in the database when you insert?
koneill385535
My image tag looked like the first one you wrote. I changed it to:
src="..images/product_images/<?php echo $row_WADAproducts["ProductImage"]; ?>"
and it still didn't work. The photo does go into the folder, but it doesn't show up on the detail page. I am attaching a photo for what the image looks like when it is saved on PHPmyAdmin.
koneill385535
Never mind, I left the ellipsis in there. I took it out and it worked well. Thank you very much!!
