Dynamic Menu linking to DataAssist results page
Thread begun 2/12/2010 5:32 am by Russell Collins | Last modified 2/16/2010 3:38 pm by Eric Mittman | 5991 views | 12 replies |
Russell CollinsBeta Tester
I have been going over the tutorial for building dynamic menus in MenuWriter.
I'm seriously confused.
The tutorial only references to a DA Details page, not a results page.
Here is my situation,
I have a products table, a category table, a lookup table (prod/cat) and an artists table with an artist id in the products table.
I want to achieve the following results
A dynamic menu selecting the categories (level 1) followed by a list of possible artists (Level 2) to then show in a DA results page (as thumbs) so they can be selected to show the details page of the product.
Any clues ?
I have searched the forum high & low and have not found anything.
I just cant seem to get any search results in a results page.
I have got the categories and artists to show as dynamic lists but that as far as I can get.
I'm falling down on the linking the DA page
Regards
Russell
You should make sure to get your DA results page working correctly first, then you can just update your menu to pass the rite value to this page to see the intended results.
For the results page you will need to define a search criteria based on the results you would like to see. So if you have a recordset that is selecting all of the items for an artists you would add in a search to the DataAssist search server behavior that would look at the artists id column and match it to a get variable for the id. It might be like this:
separator: AND
column: artists_id
type: number
comparison: =
value: <?php echo isset($_GET['artistsID'])?$_GET['artistsID']:"" ?>
You could test the page out by visiting it with the artistsID= and use a valid artists id number. You should see the items for that artists.
Once that part is worked out you would then craft your menu so that the links to the results page contained this artists id like this:
results.php?artistsID=<your artists id number>
Please post back with any additional questions that you have or if you run into any problems.
Filtering
Thanks very much Eric,
I have a much better understanding.
So, normally in step 5 of the DA wizard (search page options) I would setup up a menu for selecting each search field such as artistID, CategoryID and a check box to to view products off or online (viewable for the public), would I still do that, or leave each as the default text field and let Menuwriter place search criteria into them?
Regards
Russ
If I understand the situation correctly I think that you will want to still do it this way, but after you do that you can edit the DataAssist Search server behavior to ensure that it is configured to work with the links you craft in Menu Writer.
One of the things to think about is making sure that the search form is set to method="get" so that you can use URL parameters in place of form values to get the same results.
Search page
Eric, do I need a DA search page or could I just place a search behaviour in a results page
Russ
sending 2 url parameters
Eric,
I have managed to get the menu dynamically driven and the search behaviour as you indicated.
Here is a line of the artist search
<?php echo ((isset($_GET["S_ARTIST_idARTIST"]))?$_GET"S_ARTIST_idARTIST"]:""); ?>
Here is the line for the cat search
<?php echo ((isset($_GET["S_idCATEGORY"]))?$_GET["S_idCATEGORY"]:""); ?>
How do I send 2 url parameters in the link window to the results page?
I have the following in the there
/products_Results.php?ARTIST_idARTIST=[ARTIST_idARTIST]
The results is a blank page with this at the top
products_Results.php?ARTIST_idARTIST=1
Regards
Russell
anonymous
Hey Russell,
You should be able to accomplish it with using the "&" sign like this:
/products_Results.php?ARTIST_idARTIST=[ARTIST_idARTIST]&OtherVar=OtherValue
Regards,
Brian
Thanks for that, now all I have to work out why my results page continues to be blank !
Russ
anonymous
Perhaps a value is not getting passed like you think it is.
You could try to echo your URL vars on the page to see what happens.
If you post the code, I will also take a look and let you know if I see anything.
Regards,
Brian
Here is the search on the results page
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: WADAproducts;
//Searchpage: products_Search.php;
//Form: WADASearchForm;
$WADbSearch1_DefaultWhere = "";
if ((isset($_POST["Search_x"]) && $_POST["Search_x"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch1->addComparison("ARTIST_idARTIST","".((isset($_POST["S_ARTIST_idARTIST"]))?$_POST["S_ARTIST_idARTIST"]:"") ."","AND","=",1);
$WADbSearch1->addComparison("idCATEGORY","".((isset($_POST["S_idCATEGORY"]))?$_POST["S_idCATEGORY"]:"") ."","AND","=",1);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_products_Results"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_products_Results"]) && $_SESSION["WADbSearch1_products_Results"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_products_Results"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
