Uploading files
Thread begun 2/10/2010 11:19 am by production400659 | Last modified 2/19/2010 4:05 am by production400659 | 2902 views | 6 replies |
production400659
Uploading files
is there a way to mass upload files to server -- use FTP?
Jimmy Wu
What files are you trying to upload?
production400659
files
the read me files state you should first upload the files to your live servrer but do not clarify which files to upload. I assume is means all files that were extracted from the zip files. Is this correct?
Jimmy Wu
Yes, you would upload all the files to your server. FTP would work to send all your files to the server.
Are you using PowerStore 2 or PowerStore 3? If you are using PowerStore 2, you will have to run the store.sql from the Database directory included in the PowerStore200 directory. If you are running PowerStore 3, you will just have to follow the instructions from the installation wizard.
Neil Beadle
Uploading Solution Pack files
Have you read this?
sp_upload_files.php
The first line states...
  ...you will want to upload all the files and folders that have been provided in the .zip file
production400659
install wizard
I loaded all the files using CS4 ftp. However the installation wizard is not running? any help? now I stuck on step 2 will check other posts
production400659
help
getting error on step three of installation reading "file not saved in database" This will not allow me to establish a admin password and user name.
