Has DFP Update been fixed?
Thread begun 2/09/2010 9:12 pm by paul386190 | Last modified 2/10/2010 10:23 pm by anonymous | 1429 views | 1 replies |
paul386190
Hi there, I appear to be experiencing exactly the same problem that a number of other users have reported on using DFP on an update page - the WA Upload File server behavior isn't retaining what is being set in the default file region. I've looked through the forum and seen several occurences, the closest of which is showthread.php?t=7317, but no definitive answer as each time the person is being directed to open a support ticket.
I've tried setting the hidden form field and also the current image name directly out of the database. But each time you then go back into the server behavior it is blank again.
I would be grateful if WA could inform if this is a known issue and hoe we can resolve it.
Many thanks in advance
Paul
EDIT: Apologies, I have now managed to resolve the issue. It appears that the binding of the default file name in the upload server behavior was playing up, but is now sorted.
anonymous
Paul,
glad to hear you got things worked out... also something to keep in mind if you run into a quirk like this in the future - I found that once in awhile, after you set the default file in DFP, you have to "tab" or hit return while in the focus of the input after setting and that fixes any of those issue. It only seems to pop up intermittently with me.
Best regards,
Brian
