Help... DFP Update not working
Thread begun 11/10/2009 8:57 am by mrs | Last modified 11/12/2009 4:40 pm by Dani Chankhour | 9265 views | 11 replies |
mrs
I have been trying this now for a good four or five hours, and I can't get it to work. I used to be able to do it fine in DFP1, but I am using version 2 now and the online videos don't match version 2, even though I have managed to figure out the differences... or at least I think I have.
I have entered content into the db via the insert, the image has uploaded and is displaying great from the insert page.
It is also working great from the update page if I want to update the image... however, the problem is that if I just want to update text and NOT the image, the data that is already in the update field is not being passed over as default and deleting the info for the image that is already there.
In the DFP panel, I have set...
File field: imagenameFile
Default file: imagename (from the Update Form info which is the hidden field)
Upload: images/stock/
File name: [Filename]
In the Update Record behaviour from the server behaviours panel I have set...
Select imagename in list
Click lightning bolt
Choose Server File Name from Upload File
The code for the page is attached.
Dani Chankhour
What version of Digital File Pro are you using?
Our latest dot release should have fixed this issue.
mrs
I'm using 2.0.2 which if my downloads area is correct is the latest download available. Well, it's kind of a comfort that I am using the tool correctly, but I've still wasted over five hours of my day trying again and again to get it to work!
Is what I have done correct?
Is 2.0.2 the latest release?
In the code I have posted, what can I put right to ensure it is corrected? Have you looked at the code to see if I have been using the tool correctly?
contact318852
update record deletes other columns
I was just about to post a thread about this issue as well and saw this so I am tagging my issue here too.
I have DigitalFilePro 2.02 and can update a record, and get filename in database, however if I return to the update form and leave some of the fields blank, it will erase any entry in the database that wasn't updated with a file.
some specs digitialfilepro 2.02
dreamweaver cs3
windows vista home premium
64 bit
anonymous
contact,
It sounds like you need to populate your form fields on your update page with the existing values in the database... that way, regardless of whether you edit them or not, the original value is submitted. if you have any questions how to do this, just drop a line here.
Best regards,
Brian
contact318852
update
thanks for the prompt reply,
I thought my hidden field was doing that, is this enough code for you to determine if I have entered it correctly? - following the tutorial...
Ive added more code sample here..
// WA_UploadResult1_1 Start
'UploadFolder' => "images/profile",
'FileName' => "images/profile/".$_SESSION['MemberID'] ."_avatar",
'DefaultFileName' => "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."",
'ResizeType' => "2",
'ResizeWidth' => "120",
'ResizeHeight' => "120",
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End?>
<tr>
<td class="WADADataTableCell"><input type="hidden" name="AvatarFileName" id="AvatarFileName" value="<?php echo(str_replace('"', '&quot;', $row_WADAmember['AvatarFileName'])); ?>" size="32" />
<input type="file" name="AvatarFileNameUPD" id="AvatarFileNameUPD" /></td>
</tr>
Edit> As I explore this more I realize this is strange, some fields seem to work ok and do not get deleted on a new update, others do not. I have manually edited the code to read the existing values, but some fields wont let the edits 'stick' if i go back into the WA Upload files wizzard it occaisionally looses the 'default filename' code.
I hve moved my question to this thread showthread.php?p=29174#post29174
anonymous
One thing I noticed is that you have your DFP files flipped... the file you are uploading - meaning $WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] should be in the File Name of the DFP since that is the one that is actually being uploaded or changed. The Default file name is used to specify the image that will be used (typically the previous one uploaded) in the case that there is no image uploaded on the update page. To code this correctly, you should actually store the recordset value from the image field into a hidden field on your form... then inside the DFP dialog box, you would set the Default File to the hidden form field containing your image value from the original recordset.
Also, with the rest of your fields on the form, be sure that you are actually just populating the input fields themselves... you shouldn't need to use hidden fields for the non-image or non-file upload fields.
Regards,
Brian
mrs
Brian, who was that reply to?
As far as I am aware I posted a request for help and I haven't seen anything that is helping me!
When I do an update, the fields, radio buttons, menus etc whatever they be are populated correctly. I have even tested the page before turning the text field into a hidden field and it is getting populated...
So, on that basis, when I turn the text field to a hidden field, it should be getting db info, but it is in the process of submitting that the hidden form content is being erased and is giving me a blank db field. All other content is entering into the db OK. Therefore, I can only assume that I am either doing something wrong with the Update Record process, or, I am in fact doing it correctly, but the code is broken.
If I load a new image to update the file field content via the update page, then the db field is populated with the correct info.
Actually, can I have you promote this to a support ticket please?
contact318852
Sorry for butting into your thread,
I assumed our issues were the same bug... I didnt realize the confusion it would cause.
I will post in another thread.
Dani Chankhour
Originally Said By: mrs
Yes, i can open a support ticket if if you are still experiencing the issue.
But before, i would like to try one other thing. In the Upload Server behavior try binding the Default file to the 'mainimage' column from your record set. this way if no new image is used then the DataAssist Server Behavior should use the default image which you get from the record set.
Let me know if you still have questions.
