Cannot connect to mysql
Thread begun 2/07/2010 1:42 am by J7HNW | Last modified 2/08/2010 11:21 am by Office Guy-172461 | 4146 views | 5 replies |
J7HNW
Hi
Have just bought ECart 5 so need to learn how to work this in PHP. I always used ASP but figured I need to switch as you have dropped ASP. So I need to set up my first SQL database.
I have installed XAMP as per instructions on your site . If I hit the URL localhost - all is running properly , PHP info looks good etc etc
So my local testing server is set up. I set it to run as a service when Windows 7 starts
However when I go into Dreamweaver and open a PHP file - and then try to add a MySQL connection - I get stuck
I get a screen - and I am setting as follows. I am trying this with "root" and no password as I cannot get in wth anything and I gather this is the default User
Connection name : hair
MySql: localhost
User Name: root
Password:
Database
When I browse for the database - I am gettng MySQL Error#:1045
Access denied for user 'root'@localhost ( using password: NO )
Please can you help . I need to get the site done quickly and just need to get started
John
Office Guy-172461
Have a look at:
Logging into a MySQL database
149/
Creating a dynamic site definition in Dreamweaver
151/
J7HNW
Problem
Hi and thanks for your reply.
I am using XAMP. When I try to log in as "root " which is clearly stated as a super user in your "logging into a database " article - I am not allowed in. It says Root does not reequire a password - so I am entering root as user and leaving the password field blank
The site is set up correctly as per your other aricle - except my XAMP is in the folder
c:\xammp\xammp\htdocs . It is not a powerstore site so I have not applied this path.
Indeed I have set up a site called Hair for men as follows
c:\xammp\xammp\htdocs\Hair for men\httpdocs\
This is where my php files are stored. Under httpdocs - I have added a folder called data - and the SQL database is in the data directory
c:\xammp\xammp\htdocs\Hair for men\httpdocs\data\
I should in theory be able to log in and browse to this file - shouldnt I ?
Office Guy-172461
I think you missed this note:
Note:
The name should not include any spaces or special characters. You should never use spaces or special characters in folder or file names for a website, because they cause problems on most PHP servers.
You can't just put a database into a folder. It must be imported into your mySQL server:
Exporting and Importing a database using phpMyAdmin
150/
J7HNW
Thanks - but still a problem
Hi and thank you for your speedy response.
I have renamed the site Hairformen so all folders now have no spaces ( sorry I did miss this )
Local Info now reads
Root folder is now : C:\xampp\xampp\htdocs\Hairformen\httpdocs\
Root images folder : C:\xampp\xampp\htdocs\Hairformen\httpdocs\images\
Testing Server PHP MySQL
Access: Local / Network
Testing server folder: C:\xampp\xampp\htdocs\Hairformen\
URL Prefix: Hairformen/
I have gond to the URL localhost which opens up PHP Admin
Here I am being asked for a User name and Password to log in
I have typed in root and left the password blank - and yet again I still cannot get into the Admin Panel to set up my database.
I am sorry for the confusion - I have done many ASP sites but cannot get my head around this. Hope you can help. Once I have managed to get the database into the site I am hoping there will be similarities on the PHP pages to the ASP I have always worked with.
Thank you
John
Office Guy-172461
When you setup XAMPP you should have been asked to supply a password for mySQL. That is the password it's asking for.
