getting close
Thread begun 2/05/2010 8:22 pm by flhomesites394744 | Last modified 2/08/2010 9:42 am by Jason Byrnes | 1160 views | 1 replies |
flhomesites394744
getting close
You helped me a lot, but I have one more issue.
Where in the code can I change the default address of the center of the map? I need to move the map upward.
I am not using a DB, I entered each address in the wizard, but I want to make the change directly in the code, not the wizard.
THANKS!!!
the code that sets the default for the map if address look up fails is:
else {
map.setCenter(new GLatLng(37.4419, -122.1419), 13);
you can change the latitude and longitude used in the first argument of the GLatLng function.
