My Ecart Bug
Thread begun 3/06/2009 5:42 pm by mike292921 | Last modified 3/09/2009 8:53 am by Ray Borduin | 4643 views | 3 replies |
mike292921
My Ecart Bug
Here is the problem I am having.
you have the option in your browser to enter www.example.com or example.com.
Now for some reason when that happens the cart creates I suppose 2 cookies actually thinking its 2 different carts on 2 different websites just simply because I don't enter the www. I have my links on preset to www.example.com so anything added without the www won't be added in the same cart.
I don't know what to do. Its not a major problem, but just want some advise.
Thank You,
Mike
Miguel
i have the same problem so i forced every link without the www cause when we got the ssl it was for the domain without the www
mike292921
Still won't solve problem
Sade thank you for your response but that won't exactly solve the problem and I will tell you why you will have the same problem too even if you changed your links to example.com.
Say people are used to type www.example.com then if they click your links and it changes to example.com it will cause the same exact problem how do you allow both to work.
Go ahead and try it out.
This is the way browsers work. A different domain will have different cookies and therefor different sessions. The only solution is to always use one type of link... either always include the www or always don't... then add some domain checking on top of the page to make sure to correct the domain if it is entered differently.
