canadian addresses not showing up correctly
Thread begun 2/04/2010 7:34 am by sandy170299 | Last modified 2/04/2010 4:29 pm by Jimmy Wu | 3114 views | 6 replies |
sandy170299
canadian-hunting.php
On this map, there are two Canadian addresses, but it keeps centering to the middle United States. How can I get Canada to show up instead of the U.S.?
When I create a map with your address it centers correctly. What is the second address you are using? Also, what other options have you selected in the map wizard that weren't the default?
Try creating a map in a different site on a blank page to see if that works.
sandy170299
It might be the set zoom. Not sure. I'll try removing that.
sandy170299
Jimmy, here is code from a different page that is doing the same thing with a Canadian address. I removed the set zoom code, but it's still not centering correctly.
I'm attaching the text file.
sandy170299
Jimmy, this is all screwed up. I followed the wizard, but I'm getting two totally different views from two separate maps. How on earth do I fix this?
canadian-fishing.php
sandy170299
Jimmy, I've recreated everything and I think it's okay now. I still don't like the default zoom, but I can work around it.
I apologize for the inconvenience that this has caused you. If you run into any additional issues, feel free to open a new thread.
