WA_SecurityAssist/WA_RandomPassword.php error
Thread begun 5/09/2009 8:58 am by christerfredrickson378535 | Last modified 4/13/2010 11:27 am by Andrew Read | 6706 views | 10 replies |
Hello Folks,
I need help please with an error. I did the set-up solution 3 times to the T and still get this error when I try to login:
Warning: require_once(WA_SecurityAssist/WA_RandomPassword.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/m/a/r/marla007/html/signup_EmailPW.php on line 3
Fatal error: require_once() [function.require]: Failed opening required 'WA_SecurityAssist/WA_RandomPassword.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/m/a/r/marla007/html/signup_EmailPW.php on line 3
Anyone have any ideas? I thank you in advance.
It means the file referenced wasn't uploaded to the server:
Make sure that file exists and is uploaded and the error should go away.
Yup, I sent in a ticket and they told me this was a common error and sent me the files to put them in manually.
Now, when I login (with correct login info) I get sent to the forgot email page and I'm asked for me email so that I may be sent a new password. After submitting my email I still do not get an email.
Any ideas why?
Thanks for your time,
Christer
Spam blocking is a likely culprit if you have no errors.
paul377172
I'm getting the same problem with the asp version. The include files aren't being generated.
<!--#include file="../WA_SecurityAssist/WA_SHA1Encryption_vb.asp" -->
<!--#include file="../WA_SecurityAssist/WA_RandomPassword_vb.asp"-->
The error on the webpage
is Active Server Pages error 'ASP 0126'
Include file not found
/manageproducts/users_Registration.asp, line 2
The include file '../WA_SecurityAssist/WA_SHA1Encryption_vb.asp' was not found.
You can search your computer for those files and copy them to the correct location manually.
Another option is to add a binding to a page using the random password and encryption formats. It should move those files to the correct location whenever the binding is used, it may not have worked when you applied it for some reason... did you use the bindings panel?
You can either find and move the files manually or try using the binding a couple of times and hopefully it will work.
paul377172
Thanks I put the support ticket in and they sent me the files. Having read one of your other threads I wanted to have an email sent to the person who registers and for them to activate by clicking on a link in the email. I figured you needed to use securityassist to create a random password and use dataassist to store that password using insert record, but my problem is that I can't seem to get universal email to work with the registration page created by security assist. I've tried using both asp mail and asp email and its not a spam thing because I've it with data assists forms and forms created with dreamweaver and they all work with universal email. Is there any reason why its not working with security assist registration form. I thought it might be form action but when i left it blank it still didn't send.
Thank you
paul377172
Its ok I sorted that out by putting the UE code at the top of the page
Andrew Read
This is yet another "known issue" that should be put into the known issues folders...! Along with the required files.
These files were put into the completley wrong folder by Security Assist...
When will this be fixed?
Any issues found in Security Assist will be fixed in the next update. What is the exact issue you ran into, I'll make sure it was logged as a bug and can be addressed.
