PHP Error!
Thread begun 1/27/2010 10:51 am by peterlethbridge399499 | Last modified 1/27/2010 2:12 pm by Dani Chankhour | 1661 views | 2 replies |
PHP Error!
I've uploaded my page (and menu) to my server, but I get the following message when trying to open the page on the server:
Fatal error: Call to undefined function virtual() in /home/thebottl/public_html/createorder.php on line 983
Which files am I missing to get the page to load correctly?
Regards
Peter
another issue
I've managed to get around the above problem by changing the virtual command into an include command. However, on the remote server it only displays the menu as an unordered list.
createorder.php
Any ideas?
Dani Chankhour
The problem is with the path your images.
If you open your CSSMenuWriter/cssmw/menu.css file, you could see that your images are referenced to use file system:
background-image: url("file:///Macintosh HD/Applications/MAMP/htdocs/.../www/CSSMenuWriter/cssmw_images/bg.jpg");
please change it to use document relative:
background-image: url("/CSSMenuWriter/cssmw_images/bg.jpg");
I'm not sure why the css was generated using absolute file path, but you might want to check your side definition to ensure it is set up correctly.
