Reset Button
Is there an easy way to add a reset button that looks like the submit image in the Contact form solutions pack. This is the text I have now.
<a href="contactus.php">Reset the Code</a>
If you want a button that just resets the form (but won't reset the captcha image):
Insert > Form > Button - and in the Properties Panel/Inspector set the action to 'Rest Form'
Make sure that the button is inside the form tags.
Insert a button - Insert > Form > Button
In Properties Panel/Inspector, for 'Action' select 'None' - give it a value, i.e 'Reset'.
Go to Window > Behaviors and in the Behaviors Panel, click the plus sign and from the options select 'Go to URL'. Enter 'contactus.php' for the URL.
In your contact_styled.php page, you will have to find the image code:
<img src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=<?php echo $WAGLOBAL_Captcha_Noise; ?>&bgcolor=<?php echo $WAGLOBAL_Captcha_BG; ?>&textcolor=<?php echo $WAGLOBAL_Captcha_Text; ?>&transparent=<?php echo $WAGLOBAL_Captcha_BG_transparent; ?>&characters=<?php echo $WAGLOBAL_Captcha_Characters; ?>&width=<?php echo $WAGLOBAL_Captcha_Width; ?>&height=<?php echo $WAGLOBAL_Captcha_Height; ?>&font=<?php echo $WAGLOBAL_Captcha_Font; ?>" alt="security code"/>
Add an id to it like this:
<img src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=<?php echo $WAGLOBAL_Captcha_Noise; ?>&bgcolor=<?php echo $WAGLOBAL_Captcha_BG; ?>&textcolor=<?php echo $WAGLOBAL_Captcha_Text; ?>&transparent=<?php echo $WAGLOBAL_Captcha_BG_transparent; ?>&characters=<?php echo $WAGLOBAL_Captcha_Characters; ?>&width=<?php echo $WAGLOBAL_Captcha_Width; ?>&height=<?php echo $WAGLOBAL_Captcha_Height; ?>&font=<?php echo $WAGLOBAL_Captcha_Font; ?>" alt="security code" id="captchaImage" />
Then you will have to add a script like this:
<script language="JavaScript">
function reloadImage() {
var now = new Date();
if (document) {
document.getElementById('captchaImage').src = "WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=" + "<?php echo $WAGLOBAL_Captcha_Noise; ?>" + "&bgcolor=" + "<?php echo $WAGLOBAL_Captcha_BG; ?>" + "&textcolor=" + "<?php echo $WAGLOBAL_Captcha_Text; ?>" + "&transparent=" + "<?php echo $WAGLOBAL_Captcha_BG_transparent; ?>" + "&characters=" + "<?php echo $WAGLOBAL_Captcha_Characters; ?>" + "&width=" + "<?php echo $WAGLOBAL_Captcha_Width; ?>" + "&height=" + "<?php echo $WAGLOBAL_Captcha_Height; ?>" + "&font=" + "<?php echo $WAGLOBAL_Captcha_Font; ?>" + "&time=" + now.getTime();
</script>
and a button that calls the reload function like this:
<input type="button" name="Button" id="button" value="Button" onclick="reloadImage()" />
I can get the button working following your instructions but the refreshed image I get is ugly and unreadable.
This is the code that generates my captcha image. It was created with form builder:
<img src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=captchaField&transparent=false&noisecolor=99CCCC&noiseorder=0&gridfreq=25&gridcolor=FFFF00&gridorder=0&font=Fonts/MYTYPE.TTF&characters=6&textcolor=333333" alt="Security Code" class="Captcha" id="captchaImage" />
How do I translate that into the js script.
change:
to:
document.getElementById('captchaImage').src = "WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=99CCCC&bgcolor=FFFF00&textcolor=333333&transparent=false&characters=6&font=Fonts/MYTYPE.TTF&time=" + now.getTime();Hope you can help me out here, I get the idea, but having different values than these examples is throwing me off. (just refresh the captcha image only)
<div class="fieldGroup"> <img src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=Contact_me_group_Security_code&width=140&height=50&bgcolor=000000&transparent=false&noisefreq=25&gridfreq=50&gridcolor=FFFFFF&gridorder=0&font=Fonts/MODERNA_.TTF&textcolor=990000" alt="Security Code" class="Captcha" /> </div>
you just need to add an id to the image tag:
<div class="fieldGroup"> <img src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=Contact_me_gr oup_Security_code&width=140&height=50& bgcolor=000000&transparent=false&noisefreq =25&gridfreq=50&gridcolor=FFFFFF&grido rder=0&font=Fonts/MODERNA_.TTF&textcolor=990000" alt="Security Code" class="Captcha" id="captchaImage" /> </div>
and add the script as:
if (document) {
document.getElementById('captchaImage').src = "WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=Contact_me_gr oup_Security_code&width=140&height=50& bgcolor=000000&transparent=false&noisefreq =25&gridfreq=50&gridcolor=FFFFFF&grido rder=0&font=Fonts/MODERNA_.TTF&textcolor=990000";
</script>
It works except it resets the formatting on the captcha. How to change that? contact.php
