display uk date - datepicker
Thread begun 1/25/2010 11:18 am by dylan399236 | Last modified 2/23/2010 12:16 pm by mr hankey | 7858 views | 21 replies |
dylan399236
Hi all.
Just subscribed to the library and am looking for short guide on how to have datepicker display UK format date, then submit to DB in standard MySQL DATE format.
I can create a css form.
Have got date picker working within PHP page but cannot get it to display DD/MM/YYYY.
DB field is set to DATE.
I have seen the REFORMAT option within the VALIDATION TOOLKIT but am not sure of order to do things and am not having any luck.
Can someone tell me the settings I need to use? I realise I can muck about with hand-coding str_to_date() but that's not why I bought into Webassist :) (i did look through the forum).
Hoping the support is going to make up for my initial disappointment in the way the WA extensions are tied together (am used to Interakt/ADDT)!
Dylan.
Dani Chankhour
there is a couple of changes that you will need to make, but we should be able to change the format.
First, look for this line of code:
changeMonth: true,
changeYear: true,
and change it to:
changeMonth: true,
changeYear: true,
dateFormat: 'dd/mm/yy',
the second thing is changing the spry validation. at the bottom of your page, look for a string 'mm/dd/yyyy' and change it to 'dd/mm/yyyy'
this should allow you to have UK date format.
dylan399236
Many thanks Dani
I'll give that a go when I get back home from the day job.
Dylan.
mr hankey
thanks for that, i was looking for this solution also, works fine.
one thing though, how do i change the years to show olderas in for a date of birth? when i add this it shows from year 2000?
many thanks
Dani Chankhour
I was not able to find a way to change it to display a year less than 2000.
here is the page the list the options that you can add or modify of the datepicker:
#option-maxDate
mr hankey
thanks dani,
i found this line of code but what file and where do you edit it?
Control the range of years displayed in the year drop-down: either relative to current year (-nn:+nn) or absolute (nnnn:nnnn).
Code examples
Initialize a datepicker with the yearRange option specified.
$('.selector').datepicker({ yearRange: '2000:2010' });Get or set the yearRange option, after init.
//getter
var yearRange = $('.selector').datepicker('option', 'yearRange');
//setter
$('.selector').datepicker('option', 'yearRange', '2000:2010');
thanks
Dani Chankhour
good work.
You can add this line of code:
yearRange: '1980:2020',
right under this line, which you added:
mr hankey
thanks dani
neilo
Cheers for that Mr H and Dani.
dylan399236
Hi Dani
Sorry for going AWOL after my post but was unwell for couple of days.
Your solution is only partially working for me. The date is now displayed in UK format dd/mm/yyyy after using datepicker and I get no validation errors when submitting but the date is in the database as 0000-00-00
Bit confused as it seems to have worked for mr hankey!
Dylan.
I've attached as a txt file if you could see what's going on(or what I'm missing)?
This was with a fresh PHP file, adding fresh CSS form with 3 fields
