download counter And extra info question
Thread begun 5/07/2009 8:21 am by Paul | Last modified 4/13/2010 8:47 am by Jason Byrnes | 9282 views | 17 replies |
PaulBeta Tester
Hi, I hope I've managed to provide enough info/context around my question.
I'd like to insert extra information as well as the download count, in a table. My objective is to capture the download history of logged in users.
The MySQL table is setup with the fields "idx, user_id, filename, date, file_count". (my additional information requirement)
However, the DFP wizards default behaviour appears to only insert the download count value into a specified table - no options to insert addiional info.
Does anyone know how to add the additional information?
Unless i've overlooked something, the solution recipe does not provide anything I can use.
Any help appreciated. Thaks, Paul.
If you use DataAssist to do the insert you should be able to insert into whatever columns you want to. The DFP wizard will only help upload and download the files you still need DataAssist to manipulate the database.
Heckie
I've set up my download counter and it works great. The only problem I have is that I need to refresh the page to see the updated count.
How do I get the form to refresh the page with the updated count value?
At the moment I have this (orderdetails.php it the page with the download button):
<form action="orderdetails.php?ID=<?php echo $row_WADAmusic['DetailOrderID']; ?>" method="post" name="downloadform" id="downloadform">
Make sure your update code is above your recordset.
Heckie
Not sure what you mean by update code? Can you give me an example?
At the moment the form containing the download button just posts with no action:
<form method="post" name="downloadform" id="downloadform">
<input name="download" type="image" id="download" value="Download" src="../images/design/download2.gif" alt="Download" />
</form>
I am referring to the code above the <html>. What does that look like?
Heckie
Here is the complete php section of my orderdetails pae:
//WA eCart Include
require_once("../WA_eCart/HeckieCart_PHP.php");
<?php require_once('../Connections/connHeckie.php'); ?>
$HeckieCart->GetContent();
<?php require_once("../WA_DigitalFilePro/HelperPHP.php"); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$currentPage = $_SERVER["PHP_SELF"];
$maxRows_WADAorderdetails = 1000;
$pageNum_WADAorderdetails = 0;
if (isset($_GET['pageNum_WADAorderdetails'])) {
$pageNum_WADAorderdetails = $_GET['pageNum_WADAorderdetails'];
$startRow_WADAorderdetails = $pageNum_WADAorderdetails * $maxRows_WADAorderdetails;
$WADAID_WADAorderdetails = "-1";
if (isset($_GET['ID'])) {
$WADAID_WADAorderdetails = (get_magic_quotes_gpc()) ? $_GET['ID'] : addslashes($_GET['ID']);
mysql_select_db($database_connHeckie, $connHeckie);
$query_WADAorderdetails = sprintf("SELECT * FROM orderdetails WHERE DetailOrderID = %s ORDER BY DetailItemName ASC", GetSQLValueString($WADAID_WADAorderdetails, "int"));
$query_limit_WADAorderdetails = sprintf("%s LIMIT %d, %d", $query_WADAorderdetails, $startRow_WADAorderdetails, $maxRows_WADAorderdetails);
$WADAorderdetails = mysql_query($query_limit_WADAorderdetails, $connHeckie) or die(mysql_error());
$row_WADAorderdetails = mysql_fetch_assoc($WADAorderdetails);
if (isset($_GET['totalRows_WADAorderdetails'])) {
$totalRows_WADAorderdetails = $_GET['totalRows_WADAorderdetails'];
} else {
$all_WADAorderdetails = mysql_query($query_WADAorderdetails);
$totalRows_WADAorderdetails = mysql_num_rows($all_WADAorderdetails);
$totalPages_WADAorderdetails = ceil($totalRows_WADAorderdetails/$maxRows_WADAorderdetails)-1;
$colname_rsOrder = "-1";
$colname_rsOrder = (get_magic_quotes_gpc()) ? $_GET['ID'] : addslashes($_GET['ID']);
$query_rsOrder = sprintf("SELECT *, DATE_FORMAT(OrderDate, '%%W %%D %%M %%Y %%r') as OrderDate FROM orders WHERE OrderID = %s", GetSQLValueString($colname_rsOrder, "int"));
$rsOrder = mysql_query($query_rsOrder, $connHeckie) or die(mysql_error());
$row_rsOrder = mysql_fetch_assoc($rsOrder);
$totalRows_rsOrder = mysql_num_rows($rsOrder);
$colname_rsDownloadFile = "-1";
if (isset($_POST['fileID'])) {
$colname_rsDownloadFile = (get_magic_quotes_gpc()) ? $_POST['fileID'] : addslashes($_POST['fileID']);
$query_rsDownloadFile = sprintf("SELECT * FROM orderdetails WHERE DetailsID = %s", GetSQLValueString($colname_rsDownloadFile, "int"));
$rsDownloadFile = mysql_query($query_rsDownloadFile, $connHeckie) or die(mysql_error());
$row_rsDownloadFile = mysql_fetch_assoc($rsDownloadFile);
$totalRows_rsDownloadFile = mysql_num_rows($rsDownloadFile);?>
WA_DFP_SetupDownloadStatusStruct("WA_DownloadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_DownloadFile("WA_DownloadResult1", "../downloads/", "".$row_rsDownloadFile['DetailDownloadFile'] ."", "[FileName]", 1, $database_connHeckie, $connHeckie, "orderdetails", "DetailsID", "".$row_rsDownloadFile['DetailsID'] ."", "DetailDownload");
$queryString_WADAorderdetails = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_WADAorderdetails") == false &&
stristr($param, "totalRows_WADAorderdetails") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_WADAorderdetails = "&" . htmlentities(implode("&", $newParams));
$queryString_WADAorderdetails = sprintf("&totalRows_WADAorderdetails=%d%s", $totalRows_WADAorderdetails, $queryString_WADAorderdetails);
// WA eCart Redirect
if ($HeckieCart->redirStr != "") {
header("Location: ".$HeckieCart->redirStr);
Where is the download counter incremented? I thought I would see some sort of update statement on the page?
How do you display the download count?
Heckie
I have basically just placed a bit of dynamic text followed by / 5 (<?php echo $row_WADAorderdetails['DetailDownload']; ?> / 5)
When do you increment DetailDownload?
