Is it possible to wrap a long text link?
Thread begun 5/06/2009 1:54 pm by randy294090 | Last modified 7/06/2009 7:49 am by pbatts383773 | 4185 views | 3 replies |
randy294090
I have several long text navigations that I would like to wrap to 2 lines rather than just make the menu very wide just for several menu subsections.
Is there a way to code on the css file to wrap the text?
Randy
You can remove the white-space:nowrap: references in the css and that should allow it to wrap.
pbatts383773
Hello,
I am new to MenuWriter and have been looking for an answer to this same question. Is this also the best/only way to do this in MenuWriter2? Can this be done from the interface?
Paul
pbatts383773
Change white-space: nowrap; to white-space: normal; in menu.css
Works perfectly. No other adjustments needed. Example: www.deutschconnector.com
There are also five other ways, including nowrap, to handle white space. Perhaps a field could be added to the interface to handle this.
PB
