yet another IE6 problem
Thread begun 5/05/2009 6:05 pm by tlpirc372764 | Last modified 7/17/2009 6:57 am by Ray Borduin | 2737 views | 3 replies |
tlpirc372764
Ok guys, yet another IE6 problem here. I am creating a website which has three styles (essentially two other "home" pages if a client wants to browse the site with a different feel. This is not really the problem, essentially I created three versions of the same site, on the first style, I had serious problems with the "disappearing drop down" bug IE has, so I essentailly bumped the content div down a few pixels from the top navigation bar and, though not exactly the look I wanted, it works. (I've searched for fixes and none of them worked properly) all other browser worked fine. This also resolved an issue with the drop down disappearing behind images (not just flash) Here is a list of problems I am having and I am pulling my hair out.
the second style is a full width header, I set the navigation outside of the body so it too would be full width and set another div inside of it, right now it doesn't have position assigned to it, relative nor absolute helps. I set the margins on the right so it wouldn't float allway to the left. the menu works fine in current versions of opera, safari, konqueror, FF, IE7 and IE8 but in IE6 the customized buttons (right left center, righthover, lefthover, center) disappear and just leave huge fonts without spacing in it's place.
in the third style I set two divs inside the topnavigation div and floated one to the right and other to the left, one for the nav buttons and the other for a search field. here the buttons disappear but the proper sized links are left in their place, also there seems to be a black line underneath the top navigation div (I assume this is an issue of height with IE6) this style was set as content, two column, header, footer fixed (using sculptor) and one more thing (if the plethora of problems isn't enough for you guys to help me with) I've set my styles as presets and when I go to menu writer the menu layout is fine (home, services, etc, etc) but the images are missing, so essentially I have to go through the whole process again to redo the same menu.
The odd thing is this, with other menu styles such as glide or bubble or whatever other menu writer has, these work just fine, the only thing I did was create a custom preset using custom images for the R L C. I set the width a bit more for content and adjusted padding and height for the test within menu writer but only one out of the three styles work in IE6, the first one. The only thing I did for the first menu was switch out images, in other words I kept the height the width the font, everything just added my own images.
anyone else run across this? I have been looking over the css and I can't seem to pinpoint the problem, I thought maybe a line height problem, but I haven't specified anything for the menu outside of menu writer.
I wish someone would put that browser out of its misery! also, anyone know of a way to preload rollovers without javascript using css? I have found some examples but can't seem to get a hold on it, I currently use 1px images tucked away out of site...something google doesn't much like. webassist's site has this problem as well, the rollover image to the nav takes a couple of seconds to load.
Do you have a url where we can view the problem. Without looking at it, it is hard to debug what the solutions might be.
bobrossi315677
IE 6 and CSS Menu Writer
I've been looking at the postings for IE6 and CSS for a solution, but there are non. As stated previously, WebAssist needs to look at these issues an post some solutions, perhaps in the form of a pdf that speaks to how to correct IE6 problems when using CSS Menu Writer and IE6, since about 18% of people still use IE6.
Do you have a url?.. how many times did you post this? I think this is my fourth reply to you this morning. Anyway I'd gladly look into it if you post a URL. Our menus are tested on IE6 and should work. I'd need to analyze your page to see why it isn't working for you.
One post on one topic is generally enough to get your point across. Please refrain from spamming the forum with repeated messages in order to get your point across. It dirties up the forum and prevents others from focusing on solving problems without adding any real benefit.
