Testing server?
Thread begun 1/12/2010 5:22 pm by james276087 | Last modified 1/15/2010 11:11 am by Jason Byrnes | 6000 views | 15 replies |
james276087
Testing server?
During my third Direction Map on web page.
But this time window pop up for setup Testing server.....drive me crazy( little)
Dosen't open PHP code window....help
thanks for reading
Please see the following tutorial on the training resources page:
Setting up a Testing Server for Windows
Setting up a Testing Server for Mac OS X
Defining a Dynamic Site in Dreamweaver
resources.php
james276087
Also i'm trying on Template.
do i need to setup the Testing server for Pro maps?
thanks u
If you are creating a static HTML map, then no, but if you are creating a dynamic map, such as one with a driving directions form on it, then yes.
james276087
After the download AAMPP, doesn't open localhost page.
what did i wrong here Jason.
thank U
It is impossible for me to tell.
Did you run the XAMPP installation wizard?
Did you follow the configuration steps in the tutorial I linked to?
Is the Apache server started?
james276087
I knew it is imposible to answer, i had to take a chance that i might made stupid mistake during install XAMPP.
i just want to ask you one more question , XAMPP Control panel show Apache and Mysql are running now but doesn't open localhost .....still no luck
thanks
What _do_ you get in the browser when going to ?
What is your OS?
If it is Windows, Do you have IIS Installed? If so uninstall it.
In the setup_xampp.bat screen, try selecting option 5 to enable IPv4 support only
james276087
CANNOT DISPLAY WEBPAGE
What is your OS?
WINDOWS XP PRO
i did check and my computer doesn't have it.
Show 5.enable IPv4 only (current: IP4/6 (auto)
ALSO WHEN I CLICK ON " Admin" show error message
thanks
"Show 5.enable IPv4 only (current: IP4/6 (auto))"
This means that you currently have it set to P4/6 (auto), select optin 5 again to toggel it to IPv4 only.
"ALSO WHEN I CLICK ON " Admin" show error message"
What is the error message?
