adding PDFs
Thread begun 1/11/2010 12:42 pm by LWag48648773 | Last modified 1/12/2010 10:33 am by Eric Mittman | 2057 views | 1 replies |
LWag48648773
adding PDFs
I found the file that needs to be changed in the new version of Power CMS. It is the config.php file located here -
HTMLEditor/editor/filemanager/connectors/php/config.php
Go to approx. line 142 and add , 'pdf' (don't forget to separate with a comma).
$Config['AllowedExtensions']['Image'] = array('bmp','gif','jpeg','jpg','png', 'pdf') ;
Then you can use the Insert/Edit Link icon to upload the PDF. I like to always set Target=Blank and leave the protocol as other. It works absolutely fantastically!
I decided to then try Word, Excel, and Powerpoint. They all work except I can't get the PPT show file to work (ppst). But that's ok. I'm happy with everything else.
What I don't understand is why these files don't upload w/o this fix to the config file. The file extensions are already listed in other lines of code. Could someone please explain that to me? Just curious.
Again - you can check out my testing page.
index.php
thank you,
Laura
The reason that this works when you edit the allowed images extensions is because the editor is limited to the image type uploads. Adding extensions to the allowed image types will allow you to upload files other than images through the upload interface. For the ppst type of files try adding in just the last three characters of the extension pst.
