Check out Fail on USPS
Thread begun 5/04/2009 7:14 pm by dan377928 | Last modified 9/22/2009 7:33 am by rob_wilkins385013 | 9312 views | 15 replies |
dan377928
Cant figure out why Iam getting this failure message
Shipping Quote Failed
We're sorry
UspsCom::DoAuth
Have you looked at the USPS full response and full request? if you can't spot the problem that way, please post the full response and I can see. Usually there is more information about the error you can find.
dan377928
WA eCart USPS Shipping Include File (Copyright 2007, WebAssist)
function WA_eCart_USPS_SetSessionDefaults($USPS_eCart) {
$_SESSION[$USPS_eCart->CartName . "_USPS" . "_Success"] = false;
$_SESSION[$USPS_eCart->CartName . "_USPS" . "_ResponseCode"] = 0;
$_SESSION[$USPS_eCart->CartName . "_USPS" . "_Quote"] = 0;
$_SESSION[$USPS_eCart->CartName . "_USPS" . "_ErrorCode"] = 0;
$_SESSION[$USPS_eCart->CartName . "_USPS" . "_ErrorDescription"] = "No Packages to Ship";
$_SESSION[$USPS_eCart->CartName . "_USPS" . "_FullRequest"] = false;
$_SESSION[$USPS_eCart->CartName . "_USPS" . "_FullResponse"] = "";
Right... but if on the fail page you write out the value of:
$_SESSION["[cartname]_USPS_FullResponse"]
then you can see what the error information from usps says
Justin Nemeth
A DoAuth error indicates your USPS account information is incorrect. Make sure to use the user id USPS gave you on registration and also double check if you are using the testing or production server. By default you will have a testing account and would use the testing URL.
dan377928
where on the failure page would i put
$_SESSION["[eCart1]_USPS_FullResponse"]
Changed to production.shippingapis.com
where is the USPS user name held in ecart,
Thanks for your help
dan377928
Also saw that you have to register to use the API, which is not clear in the Checkout wizard
dan377928
got the user name and Production server but still getting doauth error
dan377928
got the checkout to work but no shipping charges were calculated
dan377928
USPS production server will not allow access until you notify them your testing is complete.
Using testing server now and am getting this error
-2147219496Rate_Respond.DomesticRatesV2Test:clsRatesV2TestValidateParameters:clsRatesV2TestProcessRequest;SOLServerRatesTest.RateV2_RespondShipper must supply own packaging. 1000440
