Items in multiple categories
Thread begun 5/02/2009 3:44 pm by Travis250923 | Last modified 5/02/2009 4:46 pm by Travis250923 | 1558 views | 1 replies |
Travis250923
I'm trying to allow for items to be in multiple categories but I can only get one product to show on the products page. I have set up a relational table and used dataassist to combine the items table and the itemcategory. I have sorted the recordsets using the following code but it results in only the first itemid in the catlink recordset which is the relational table.
When I echo the itemid in the cat link I get the appropriate ids but when I echo itemid from the items recordset I only get one id repeated several times which means I only get 1 item on the page even though there should several. Any help would be great.
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$colname_rsCatLink = "-1";
if (isset($_GET['ItemCatID'])) {
$colname_rsCatLink = (get_magic_quotes_gpc()) ? $_GET['ItemCatID'] : addslashes($_GET['ItemCatID']);
mysql_select_db($database_waConn, $waConn);
$query_rsCatLink = sprintf("SELECT * FROM itemcategorylink WHERE ItemCatID = %s", GetSQLValueString($colname_rsCatLink, "int"));
$rsCatLink = mysql_query($query_rsCatLink, $waConn) or die(mysql_error());
$row_rsCatLink = mysql_fetch_assoc($rsCatLink);
$totalRows_rsCatLink = mysql_num_rows($rsCatLink);
$_GET['IDFORITEMS'] = $row_rsCatLink['ItemID'];
$colname_rsItems = "-1";
if (isset($_GET['IDFORITEMS'])) {
$colname_rsItems = (get_magic_quotes_gpc()) ? $_GET['IDFORITEMS'] : addslashes($_GET['IDFORITEMS']);
$query_rsItems = sprintf("SELECT * FROM items WHERE ItemID = %s ORDER BY ItemName ASC", GetSQLValueString($colname_rsItems, "int"));
$rsItems = mysql_query($query_rsItems, $waConn) or die(mysql_error());
$row_rsItems = mysql_fetch_assoc($rsItems);
$totalRows_rsItems = mysql_num_rows($rsItems);
$_GET['TEMPIDFORRS'] = $row_rsItems['ItemOptionsID'];
$MMColParam_rsOptions = "-1";
if (isset($_GET['TEMPIDFORRS'] )) {
$MMColParam_rsOptions = (get_magic_quotes_gpc()) ? $_GET['TEMPIDFORRS'] : addslashes($_GET['TEMPIDFORRS'] );
$query_rsOptions = sprintf("SELECT * FROM itemoptions WHERE ItemOptionsID = %s", GetSQLValueString($MMColParam_rsOptions, "int"));
$rsOptions = mysql_query($query_rsOptions, $waConn) or die(mysql_error());
$row_rsOptions = mysql_fetch_assoc($rsOptions);
$totalRows_rsOptions = mysql_num_rows($rsOptions);
$query_rsCategories = "SELECT * FROM itemcategory ORDER BY ItemCatName ASC";
$rsCategories = mysql_query($query_rsCategories, $waConn) or die(mysql_error());
$row_rsCategories = mysql_fetch_assoc($rsCategories);
$totalRows_rsCategories = mysql_num_rows($rsCategories);
Travis250923
Well I think I got it. I made the categorylink that is the relational table an inner join so it looks like this:
SELECT *
FROM itemcategorylink INNER JOIN items ON items.ItemID = itemcategorylink.ItemID
WHERE ItemCatID = colname
It seems to work but I'll have to test more to confirm.
