Marker text
Thread begun 12/21/2009 1:50 pm by vwdes71987 | Last modified 12/21/2009 2:02 pm by Jimmy Wu | 1459 views | 1 replies |
vwdes71987
Marker text
Is there a way to add a dynamic vaule to te markers on the map? I want to show al list of addresses, numbered from 1 tot 20 and I want these numbers as reference in the marker (instead of the dot) in the Google Map.
Is that possible?
Thanks, Martijn
If you wanted the marker symbol to change, you would be changing the actual marker image, not the text. You can add the image to the google_javascript/images directory and then in your wagmp_map_<map num>.php file find this line for each point:
icon_<address num>.image = 'plugins/google_javascript/images/<new marker>.png';
and change the <new marker>.png to be what image you want.
