HELP!!!! UNABLE TO USE JUST PURCHASED Eric Meyer's CSS SCULPTOR 3
Thread begun 12/17/2009 1:30 pm by djmolinari345108 | Last modified 12/17/2009 2:22 pm by Jason Byrnes | 3040 views | 1 replies |
djmolinari345108
When I select in Dreamweaver -> "New CSS Sculptor Page.." I get the following error. I am no longer able to use CSS SCULPTOR. I am not able to access the support forum, so I need your help.. thanks
"While executing onLoad in
wacs_quickkinsert.htm the following JavaScript error at line 145: <directory>/configuration/Commands/wacs_quickinsert.js"
NOTE: There is no
wacs_quickinsert.js in that folder. I am not able to use Eric Meyer's CSS SCULPTOR 3 I just purchased! :confused:
delete the Dreamweaver cache file from the users configuration folder:
if you still have problems, double check the following:
1) Make sure you have defined a site in Dreamweaver.
2) Create a new page, save it to the defined site and make sure that page is open before going to File -> New CSS Sculptor Page.
