Data Assist Search Question
Thread begun 4/30/2009 5:41 pm by Ian | Last modified 5/01/2009 6:39 am by Ray Borduin | 1866 views | 1 replies |
Ian
Hi Ray,
With Data Assist Search is it possible to do a "IN" query like in MSSQL.
So if I have an array of numbers (say item IDs) like this "23,54,34,76,45,54" in a session variable could I use Data Assist search to do:
Select * From products WHERE itemid IN <%=Session("array")%>
I think there is an INCLUDES query type. Would that work?
Cheers
Ian
You can use "list" type search and pass the array object as the value. DataAssist Search works with arrays directly. You probably still want to use "=" since you are looking for an exact match.
It won't exactly do an IN search, but it will achieve the same result with a complex WHERE statement joined by OR.... something like: WHERE (ID =23 OR ID=54 OR ID =34 OR ID = 76)
The same end result, so it should work for you.
