Editing profile works locally, but not online
Thread begun 12/15/2009 6:29 am by Kamen Nikolov | Last modified 12/15/2009 6:07 pm by Eric Mittman | 3989 views | 4 replies |
Kamen Nikolov
I have another problem after a got everything working. When users register, they will receive an email and they will verify their email and will login into their profile. The problem is that if I update my profile locally is working when update on-line it is not.
You can try it yourself register at users_Registration.php or users_Registration_Simple.php and try to update your profile.
I have been over the code many times and can figure it out. Tank you for your help in advance.
This is the code:
I'm not sure why the profile does not seem to be updating. I noticed that the redirect page you have in the update server behavior goes back to this same page. You should try updating this value to see if you can get to another page while testing.
To help determine what is going wrong with the SQL I have added a die statement that will print out the SQL for the update. When you load this version of the page and test it you should see the update statement that is used in the sql. This should give you a better idea about what the problem is. If you have any problems determining what is going on please post back and let us know the result you got in the sql.
Kamen Nikolov
This is the mySQL responce:
UPDATE `users` SET `UserPassword` = 'testPW', `UserFirstName` = 'Jo', `UserLastName` = 'Blow', `UserCity` = 'Town', `UserState` = 'ON', `UserZip` = 'M9M 5G5', `UserPhone` = '(555) 555-5555', `UserFax` = '', `UserCountry` = 'CA', `UserAddress` = '89 Street', `UserAddress2` = '' WHERE `UserID` IS NULL
seems to me it is not reading the userID
Kamen Nikolov
Problem FIxed
I got it. Thank you very much
Yeah, it definitely seems like it was the userID that was causing it to not work correctly. Any word on what you had to do to get it working? This info may be helpful for any other that is experiencing a similar problem.
