Display data from related tables in results
Thread begun 4/30/2009 11:48 am by phil.evans372967 | Last modified 8/27/2010 12:04 pm by Vinicios Nussemeyer | 12094 views | 16 replies |
phil.evans372967
Hi all,
I'm trying to display data in my main results pages from two related tables
prop_details
prop_images
I'd like display all thumbnails from prop_images that are related to prop_details, the relationship being prop_id
I've create a new recordset
$maxRows_WADAprop_details = 5;
$pageNum_WADAprop_details = 0;
if (isset($_GET['pageNum_WADAprop_details'])) {
$pageNum_WADAprop_details = $_GET['pageNum_WADAprop_details'];
$startRow_WADAprop_details = $pageNum_WADAprop_details * $maxRows_WADAprop_details;
mysql_select_db($database_prop, $prop);
$query_WADAprop_details = "SELECT prop_ref, prop_id, add_date, prop_type, short_desc, town, price, status, featured FROM prop_details";
$query_limit_WADAprop_details = sprintf("%s LIMIT %d, %d", $query_WADAprop_details, $startRow_WADAprop_details, $maxRows_WADAprop_details);
$WADAprop_details = mysql_query($query_limit_WADAprop_details, $prop) or die(mysql_error());
$row_WADAprop_details = mysql_fetch_assoc($WADAprop_details);
if (isset($_GET['totalRows_WADAprop_details'])) {
$totalRows_WADAprop_details = $_GET['totalRows_WADAprop_details'];
} else {
$all_WADAprop_details = mysql_query($query_WADAprop_details);
$totalRows_WADAprop_details = mysql_num_rows($all_WADAprop_details);
$totalPages_WADAprop_details = ceil($totalRows_WADAprop_details/$maxRows_WADAprop_details)-1;
$query_SelectThumb = "SELECT prop_images.img_thumb, prop_images.prop_id, prop_details.prop_id FROM prop_images, prop_details WHERE prop_images.prop_id = prop_details.prop_id";
$SelectThumb = mysql_query($query_SelectThumb, $prop) or die(mysql_error());
$row_SelectThumb = mysql_fetch_assoc($SelectThumb);
$totalRows_SelectThumb = mysql_num_rows($SelectThumb);
which makes the match (I think)
but I can't get the image file names to display in my table row in the main repeat region
<?php do { ?>
<tr class="<?php echo $WARRT_AltClass1->getClass(true); ?>">
<td class="WADAResultsTableCell"><?php echo($row_WADAprop_details['prop_ref']); ?></td>
<td class="WADAResultsTableCell"><?php echo($row_WADAprop_details['prop_id']); ?></td>
<td class="WADAResultsTableCell"><?php echo($row_WADAprop_details['add_date']); ?></td>
<td class="WADAResultsTableCell">Display all image in series related to the record here<?php echo $row_SelectThumb['img_thumb']; ?></td>
<td class="WADAResultsTableCell"><?php echo($row_WADAprop_details['prop_type']); ?></td>
<td class="WADAResultsTableCell"><?php echo($row_WADAprop_details['short_desc']); ?></td>
<td class="WADAResultsTableCell"><?php echo($row_WADAprop_details['town']); ?></td>
<td class="WADAResultsTableCell"><?php echo($row_WADAprop_details['price']); ?></td>
<td class="WADAResultsTableCell"><?php echo($row_WADAprop_details['status']); ?></td>
<td class="WADAResultsTableCell"><?php echo($row_WADAprop_details['featured']); ?></td>
</tr>
<?php } while ($row_WADAprop_details = mysql_fetch_assoc($WADAprop_details)); ?>
Can anyone help?
Phil
You are going to have to move your thumbs recordset inside your details loop and you are going to have to filter it based on the detail being displayed... then you are going to have to add a repeat region around the thumbs display line show it displays for as many thumbs as exist for that detail.
phil.evans372967
Hi Ray,
Thanks for your reply
I'm not sure what with the first part. Do you mean combine the two queries into one something like this
SELECT prop_details.prop_id, prop_details.prop_type, prop_details.short_desc, prop_details.prop_ref, prop_images.img_thumb, prop_images.prop_ref, prop_images.prop_id
FROM prop_details, prop_images
WHERE prop_images.prop_id=prop_details.prop_id
Phil
I mean cutting and pasting
You need to add a parameter to the second recordset to filter based on the first recordset. To do this you need to do the $_POST hack and set it to a posted variable and set the post variable to the recordset value manually.
Then you need to cut and paste the recordset code inside the DO loop on the page so that it is refiltered for each result.
Another possible technique is to use a joined recordset and write if statments and loops, but that takes even more hand coding.
tom92909Beta Tester
Using an INNER JOIN would be good.
"SELECT *
FROM prop_details INNER JOIN prop_images ON prop_images.prop_id = prop_details.prop_id"
Something like that should help I think....
phil.evans372967
Hi guys
Thanks for your help with this.
So far I've managed to get the page to display all the related records, but the script displays a row for each prop_id from prop_details that has a related img_thumb.
Any idea how I can get this to display just one row for each record for prop_id in prop_details and then display all related img_thumbs in one cell in the table (the one that currently shows <td><img src="../images/tns/<?php echo $row_Recordset1['img_thumb']; ?>" width="50" height="50" alt="<?php echo $row_Recordset1['short_desc']; ?>" /></td>)
Thanks again
Phil
<?php require_once('../Connections/prop.php'); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$query_Recordset1 = "SELECT prop_details.prop_id, prop_details.prop_ref, prop_details.short_desc, prop_images.img_thumb, prop_images.prop_id FROM prop_details LEFT JOIN prop_images ON prop_details.prop_id=prop_images.prop_id";
$Recordset1 = mysql_query($query_Recordset1, $prop) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 = mysql_num_rows($Recordset1);
?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
</head>
<body>
<table width="80%" border="0" cellspacing="2" cellpadding="2">
<tr>
<td>Prop ID</td>
<td>Office Ref</td>
<td>Short Desc</td>
<td>Thumbs</td>
</tr>
<?php do { ?>
<tr>
<td><?php echo $row_Recordset1['prop_id']; ?></td>
<td><?php echo $row_Recordset1['prop_ref']; ?></td>
<td><?php echo $row_Recordset1['short_desc']; ?></td>
</tr>
<?php } while ($row_Recordset1 = mysql_fetch_assoc($Recordset1)); ?>
</table>
</body>
</html>
mysql_free_result($Recordset1);
phil.evans372967
I've adapted my query further which now pulls out all the right results, but only displays the first image associated with the property record
SELECT prop_details.prop_id, prop_details.prop_ref, prop_details.short_desc, prop_images.img_thumb, prop_images.prop_id, prop_details.long_desc
GROUP BY prop_images.prop_id, prop_details.prop_id
ORDER BY prop_details.prop_ref
Can anyone guide me as to how to adapt my PHP block to acheive this?
This is what I've got so far
<body>
<tr>
<td>Prop ID From Ims Table</td>
<td>Prop ID from Deatils table</td>
<td>Office Ref</td>
<td>Short Desc</td>
<td>Long Desc</td>
<td>Thumbs</td>
</tr>
<?php do { ?>
<tr>
<td align="left" valign="top"><?php echo $row_Recordset1['prop_id']; ?></td>
<td align="left" valign="top"><?php echo $row_Recordset1['prop_ref']; ?></td>
<td align="left" valign="top"><?php echo $row_Recordset1['short_desc']; ?></td>
<td align="left" valign="top"><?php echo $row_Recordset1['long_desc']; ?></td>
<td align="left" valign="top"><img src="../images/tns/<?php echo $row_Recordset1['img_thumb']; ?>" width="50" height="50" alt="" /></td>
</tr>
</table>
</body>
</html>
With thanks as ever
Phil
Just listen to my original advice... well first you will need to add a second recordset then:
'You need to add a parameter to the second recordset to filter based on the first recordset. To do this you need to do the $_POST hack and set it to a posted variable and set the post variable to the recordset value manually.
Then you need to cut and paste the recordset code inside the DO loop on the page so that it is refiltered for each result.'
phil.evans372967
Thanks Ray
How do I do the $_POST hack and set it to a posted variable?
Cheers
Phil
phil.evans372967
Am I on the right path with this
<?php do { ?>
<form action="" method="post"><input name="$prop_id" type="hidden" id="$prop_id" value="<?php echo $row_WADAprop_details['prop_id']; ?>" />
</form>
// Make a MySQL Connection
$query = "SELECT *
FROM prop_images
WHERE prop_id = '$prop_id'
$result = mysql_query($query) or die(mysql_error());
while($row = mysql_fetch_array($result)){
echo $row['img_thumb'];
echo "<br />";
</td>
