Extension Activation Error
Thread begun 12/10/2009 5:32 am by john.applin395901 | Last modified 12/29/2009 10:52 am by Jimmy Wu | 4350 views | 8 replies |
john.applin395901
Hi all
I am getting the following error while trying to activate this recently purchased extension
'While executing load in DWC_serial.htm, the following javascript error occured:
At line 219 of file "C:\Program Files\Adobe\Adobe Dreamweaver CS4\Configuration\Shared\WebAssist\DynamicWebChart s\Library\Shared_Ser_Mactivation.js": document.formLayer.document has no properties
Does anyone have any ideas how to fix this? I have already tried deleting the dat file with no affect.
Many thanks in advance
John
There is one other thing that you should try for this, renaming the configuration folder. Here is a link with steps you can take for this:
146/
If you still have the problem let us know and we will look into this further with you.
john.applin395901
LODI baaing
Hello
Thankyou for your quick reply.
I have tried everything that you have suggested but I am still receiving the same error mesage. Is there anything else that you can suggest that I try?
Many thanks,
John.
It seems that this problem will need some further debugging to determine what the problem is. I have opened a ticket for you on this issue. To update the ticket please login to WebAssist.com and visit your support history.
We were able to generate a license.dat file for this user which allowed them to activate.
p.turpin397172
Web Assist Dynamic charts activation error
Get the same error as John and deleted the cache , restarted DW and continue to get the same message.
Rgds
Originally Said By: john.applin395901
  Hi all
John
The line of code that is referenced indicates that you are unable to connect to our server to activate the product. If you have any security, virus scan or firewall software that may interfere with this connection, please disable the software before trying to activate. If you are still getting the error, please post back and I will open up a backend ticket to generate a license file for you.
p.turpin397172
activation pb --> solved
After 2 reboots it worked fine.
Thkx for your help
Best regards
Glad to see you were able to get the extension working. If you run into any additional issues, feel free to open a new thread.
