Missing PHP Files in wwroot directory
Thread begun 12/09/2009 10:07 am by halosmoker420391145 | Last modified 12/11/2009 10:46 am by Jason Byrnes | 6112 views | 3 replies |
halosmoker420391145
I'm currently going through the video tutorials for Powershop Tutorial #4 & 5 say to transfer the E-learning folder to thw wwroot folder. I located the folder but I'm missing the PHP files there. In that folder I have :
aspnet_client
Sitefinity
iistart.htm
ELearning (Folder)
I've installed EasyPHP
So I continue the tutorial copy e learning folder to the wwroot directory, and then Start New Site in dreamweaver as directed by the Tutorial. At the end I get this message code :
The site URL prefis [/e learning] for the testing server does not match the site URL prefix [] specified in HTTP Address for the site. This may cause pages using site relative links to display incorrectly at runtime. Proceed anyway?
I elect to proceed anyway.
I thent attempt to make a Connection to mysql or "databases button on DW" I get the following message :
HTTP Error Code 404 File Not Found. Here are some possible reasons for the problem:
1. There is no testing server running on the server machine.
2. The testing server specified for this site does not map to the e learning/_mmServerScripts/MMHTTPDB.php URL.
Verify that the URL Prefix maps to the root of the site.
This is where I get stuck and am unable to move on in the tutorial.
I've been working with this issue for two dayS already... IS THERE SOMEONE OUT THERE THAT COULD HELP ME PLEASE? PLEASE.... PLEASE.... PLEASE....
This sounds like yur php server may not be running properly.
Create a new PHP file in your eLearning directory called phpinfo.php
add the following code:
<?php phpinfo(); ?>
then browse to e learning/phpinfo.php
this should display information about you php installation. If it does not, you may want to follow through our tutorials for installing a testing server
, you can find them on the following page:
resources.php
halosmoker420391145
Ok, so I created a new php file in the e-learning folder . I browsed and found a bunch of tables that gave info on how my php was configured. Does that mean it is fixed... I'll try to continue with the tutorial... I hope that worked.
Not necessarily, it just means that PHP is working.
Is the folder named "e learning" or "e-learning"?
I ask because in the error, it looks like you have the testing server URL prefix set to:
e learning/
if the folder is named "e-learning" the URL prefix should be:
e-learning/
