How to Remove Image Captcha
Thread begun 4/29/2009 1:56 pm by Gabe | Last modified 4/30/2009 6:46 pm by Gabe | 3538 views | 3 replies |
Gabe
Hello -
I'm trying to remove the hard to read image captcha from my form. I removed the php and input boxes but now I cant submit. When I try to it does nothing.
I think I need to remove the script that's associated with the image captcha but its hard to find.
Any clues?
Thanks a bunch,
Gabe
It should be spelled out with line numbers in the help documentation.
It is the code that refers to the name of the form elements you deleted. If you search for those form element names it should be easy to find the lines to delete.
Gabe
Can you point me to the documentation?
Gabe
Sorry I think I found the docs. Its index.htm? Well thank you for your tip. All is removed and working.
Great product.
Gabe
