Multiple Versions of Dreamweaver/Webassist?
Thread begun 4/28/2009 12:13 pm by Art | Last modified 7/02/2009 5:10 pm by cwalt2166 | 9339 views | 14 replies |
Art
I have a need to run older versions of Dreamweaver and WebAssist extensions.
Specifically, I need CS3 and Universal Mail 2.6 (2.6 doesn't work in CS4)
I tried having multiple versions but this broke my setup. Ended up having to remove CS3, it's extensions and and reinstalling extensions back into CS4.
After a wasted day, I got it all back working.
So how do I have CS3 and CS4 together with old and new Extensions together?
Probably not a way to do it. The extension manager won't let you have more than one of the same version installed and since the same extension manager is used across products you can't have them both installed.
Art
Where to look next?
Well, the problem I'm having is with 2.8 vs 2.6
The site I have is on 2.6 but now that I have CS4, (newly installed), it won't let me use 2.6 any more. The problem is, I can't get 2.8 working with my site; it installs, applies to the page but when I upload it, it refuses to send (CDOSYS).
It uses all the same settings and I've uploaded all the library files but now it's not working.
Any ideas where to look?
Add a die statement after the email is sent to see if there is an error message. If it isn't sending there must be a problem, you just might need to debug a little to find it.
Art
How to add a die statement?
see: showthread.php?t=575&highlight=email+die(
it talks about debugging email by adding a die statement.
Art
die statement
That example was in PHP, got one for asp?
in asp you use:
Response.Write()
Response.End
to do the equivalent of a die(); statement in php.
I would start by making sure the trigger is firing. Does it redirect when you put a redirect page in the email server behavior?
Art
We use our own mail server and that sits on a different box than the site host.
The 2.6 version works in this environment but when using the 2.8 version, it fails. Everything else is the same so it seems as though it should work.
I think I remember trying this but I don't remember how that turned out. It's been a while but is 2.6 compatible with cs4?
Art
No, it doesn't redirect.
error '80040211'
/WA_Universal_Email/CDOSYS_VB.asp, line 144
