Redirect to product results after update
Thread begun 11/23/2009 9:26 am by Joe Lowery | Last modified 11/24/2009 9:00 pm by Joe Lowery | 3902 views | 4 replies |
Joe Lowery
I'm trying to change the products update page so that it redirects to the last product result page after updating. I've gotten it to redirect to the results page that initially loads by changing line 166 to:
$WA_redirectURL = "Products_Results.php?Search=0";
What do I change the argument to so the redirect goes to the last results page displayed?
Best - Joe
try leaving the Query string variable off:
$WA_redirectURL = "Products_Results.php";
that should cause the DataBase Search behavior to use the previous search that is stored in a session variable.
Joe Lowery
That appears to work if the client uses the search engine, but not if they are paging through the recordset (which is how it is being used now). Is there anyway to have the page redirect to the previous page under both scenarios?
Best - Joe
the paging is controlled by querystring variables:
?pageNum_WADAProducts=1&totalRows_WADAProducts=12
These would need to be added to the update link on the results page:
<input type="button" name="product_update" id="product_update" value="Update" class="ie_btn_small" onclick="window.location = 'Products_Update.php?ProductID=<?php echo(rawurlencode($row_WADAProducts['ProductID'])); ?><?php echo(isset($_GET['pageNum_WADAProducts'])?"&pageNum_WADAProducts=".$_GET['pageNum_WADAProducts']:""); ?><?php echo(isset($_GET['totalRows_WADAProducts'])?"&totalRows_WADAProducts=".$_GET['totalRows_WADAProducts']:""); ?>';" /><br />
to the forms action on the update page:
 action="Products_Update.php?ProductID=<?php echo(rawurlencode($row_WADAProducts['ProductID'])); ?><?php echo(isset($_GET['pageNum_WADAProducts'])?"&pageNum_WADAProducts=".$_GET['pageNum_WADAProducts']:""); ?><?php echo(isset($_GET['totalRows_WADAProducts'])?"&totalRows_WADAProducts=".$_GET['totalRows_WADAProducts']:""); ?>"
and to the redirect:
$WA_redirectURL = "Products_Results.php?ProductID=".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"")  ."".((isset($_GET["pageNum_WADAProducts"]))?"&pageNum_WADAProducts=".$_GET["pageNum_WADAProducts"]:"")  ."".((isset($_GET["totalRows_WADAProducts"]))?"&totalRows_WADAProducts=".$_GET["totalRows_WADAProducts"]:"")  ."";
Joe Lowery
Thanks for the code, Jason. I made all the changes you suggested but I think something is off. The URL string in the address bar I see after updating is:
Products_Results.php?ProductID=59&pageNum_WADAProducts=1&totalRows_WADAProducts=45
Note the two "&" character entities. I changed those to just "&" and it worked. Thanks again.
Best - Joe
Joe Lowery
This post has been deleted.
