WA QueryBuilder error
Thread begun 11/22/2009 12:01 pm by chssagmi366905 | Last modified 11/22/2009 1:25 pm by Office Guy-172461 | 2231 views | 3 replies |
chssagmi366905
I tried to download your color pallete picker but it said it had older versions of files. I tried to remove ecart to install newer version so I could then install your color pallete, then reinstall newer ecart version, which I thought I did but now can't use dreamweaver CS3 because the following error message keeps popping up: "WA AueryBuilder RS.htm has config info that is invalid. WA Forms.htm has invalid config info" I purchased your suite package, so what do I need to do?
Office Guy-172461
I would start here:
146/
chssagmi366905
problem solved
thank you very much after deleting cache and restarting computer, twice, but everything is fine.
Office Guy-172461
Thank you for posting back your results. I will add the restart twice tip to the article.
