Pro Maps for Google 1.0.6 Dot Release Available
Thread begun 11/11/2009 11:00 am by Anna Robinson | Last modified 5/19/2010 9:15 am by Jason Byrnes | 10375 views | 18 replies |
Anna Robinson
A dot release for Pro Maps for Google is available in the Download Center of our website. Log in and visit downloadcenter.php. Click on Pro Maps for Google and download the mxp from the Extensions section.
It is best practice to uninstall your current version before installing the new version.
This main bug fixes in this release include:
- context-sensitive help wasn't loading the correct page in Dreamweaver 8.
- JavaScript error to occurred when clicking ‘Finish’ in the last step of the wizard.
- the Address marker in maps was using the default when using driving directions regardless of the marker type chosen.
dhurrell303078
onmouseup wagmp_map.htm javascript error shared.js xml no properties
we just purchased pro maps v 1.06, downloaded and installed the extension in dreamweaver cs4 PC. we click finish and get the following error:
While executing onMouseUp in wagmp_map.htm, the following JavaScript error(s) occured:
At line 451 of file "C:\Program Files\Adobe\Adobe Dreamweaver CS4\Configuration\Shared\WebAssist\GoogleMapsPro\shared.js": xml has no properties.
Can you please assist? we've have found an article in this forum that said to delete the Dreamweaver Cache.dat file then reboot. We've attempted that with no success. Any other suggestions?
Thanks in advance,
Daren Hurrell
dhurrell@infitech.net
We were able to determine this is caused by using a .aspx page. If the page is a .asp or other server language, it works correctly. The workaround would be to add Pro Maps to a page that is not a .aspx and then copy the include code to the .aspx page to get the maps applied.
toms016390756
Originally Said By: Jimmy Wu
how do you know he's using asp? just curious//
--- My baby:
We had opened up a backend ticket so that we could look into the issue further with the user. After contacting the user on the phone we were able to determine that using a .aspx page and not a .asp page causes the issue.
psherida398454
I am receiving a similar error to the one posted above except at the end it says "The object is not currently contained in a document."
I am using a PHP page if it makes any difference
Any help would be appreciated
psherida398454
This post has been deleted.
Do you have a site defined and the page is saved to that site?
cgschn380661
replace file?
When attempting to update the program with the new .mxp file, I received the following error message, and backed-out of the installation, not wanting to mess-up my current, working ProMaps for Google software. Will clicking 'Yes' have any negative affect on the delicate workings of my currently installed ProMaps for Google webpage?
The error message in question:
"The 'ProMaps for Google' extension conflicts with the existing 'ProMaps for Google' extension. The installation files for these extensions have the same name.
Do you want to replace it?
[Yes] [No]"
In the Extension manager, you need to uninstall the previous version of pro maps before installing the new version.
